/* 函数名:ADC1_Mode_Config
* 描述 :配置ADC1的工作模式为MDA模式
* 输入 : 无
* 输出 :无
* 调用 :内部调用
static void ADC1_Mode_Config(void)
DMA_InitTypeDef DMA_InitStructure;
ADC_InitTypeDef ADC_InitStructure;
/* DMA channel1 configuration */
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; //ADC地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue; //内存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = 1;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址固定
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; //内存地址固定
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//半字
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环传输
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
/* ADC1 configuration */
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //独立ADC模式
ADC_InitStructure.ADC_ScanConvMode = DISABLE ; //禁止扫描模式,扫描模式用于多通道采集
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //开启连续转换模式,即不停地进行ADC转换
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//不使用外部触发转换
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //采集数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = 1; //要转换的通道数目1
ADC_Init(ADC1, &ADC_InitStructure);
/*配置ADC时钟,为PCLK2的8分频,即9Hz*/
RCC_ADCCLKConfig(RCC_PCLK2_Div8);
/*配置ADC1的通道11为55.5个采样周期,序列为1 */
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_55Cycles5);
/* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC1 */
ADC_Cmd(ADC1, ENABLE);
/*复位校准寄存器 */
ADC_ResetCalibration(ADC1);
/*等待校准寄存器复位完成 */
while(ADC_GetResetCalibrationStatus(ADC1));
/* ADC校准 */
ADC_StartCalibration(ADC1);
/* 等待校准完成*/
while(ADC_GetCalibrationStatus(ADC1));
/* 由于没有采用外部触发,所以使用软件触发ADC转换 */
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
* 函数名:ADC1_Init
* 描述 :无
* 输入 :无
* 输出 :无
* 调用 :外部调用
void ADC1_Init(void)
ADC1_GPIO_Config();//配置IO
ADC1_Mode_Config();//配置DMA和ADC
DMA自动将ADC外设的数据寄存器(ADC_DR_Adress)的数据转移到内存中的变量ADC_ConvertedValue中。 |
