STM32使用fsmc控制NOR flash 例程(5)
* Function Name : FSMC_NOR_ReadHalfWord
* Description : Reads a half-word from the NOR memory.
* Input : - ReadAddr : NOR memory internal address to read from.
* Output : None
* Return : Half-word read from the NOR memory
u16 FSMC_NOR_ReadHalfWord(u32 ReadAddr)
NOR_WRITE(ADDR_SHIFT(0x005555), 0x00AA);
NOR_WRITE(ADDR_SHIFT(0x002AAA), 0x0055);
NOR_WRITE((Bank1_NOR2_ADDR + ReadAddr), 0x00F0 );
return (*(vu16 *)((Bank1_NOR2_ADDR + ReadAddr)));
* Function Name : FSMC_NOR_ReadBuffer
* Description : Reads a block of data from the FSMC NOR memory.
* Input : - pBuffer : pointer to the buffer that receives the data read
* from the NOR memory.
* - ReadAddr : NOR memory internal address to read from.
* - NumHalfwordToRead : number of Half word to read.
* Output : None
* Return : None
void FSMC_NOR_ReadBuffer(u16* pBuffer, u32 ReadAddr, u32 NumHalfwordToRead)
NOR_WRITE(ADDR_SHIFT(0x05555), 0x00AA);
NOR_WRITE(ADDR_SHIFT(0x02AAA), 0x0055);
NOR_WRITE((Bank1_NOR2_ADDR + ReadAddr), 0x00F0);
for(; NumHalfwordToRead != 0x00; NumHalfwordToRead--) /* while there is data to read */
/* Read a Halfword from the NOR */
*pBuffer++ = *(vu16 *)((Bank1_NOR2_ADDR + ReadAddr));
ReadAddr = ReadAddr + 2;
* Function Name : FSMC_NOR_ReturnToReadMode
* Description : Returns the NOR memory to Read mode.
* Input : None
* Output : None
* Return : NOR_SUCCESS
NOR_Status FSMC_NOR_ReturnToReadMode(void)
NOR_WRITE(Bank1_NOR2_ADDR, 0x00F0);
return (NOR_SUCCESS);
* Function Name : FSMC_NOR_Reset
* Description : Returns the NOR memory to Read mode and resets the errors in
* the NOR memory Status Register.
* Input : None
* Output : None
NOR_Status FSMC_NOR_Reset(void)
* Function Name : FSMC_NOR_GetStatus
* Description : Returns the NOR operation status.
* Input : - Timeout: NOR progamming Timeout
* Output : None
* Return : NOR_Status:The returned value can be: NOR_SUCCESS, NOR_ERROR
* or NOR_TIMEOUT
NOR_Status FSMC_NOR_GetStatus(u32 Timeout)
u16 val1 = 0x00, val2 = 0x00;
NOR_Status status = NOR_ONGOING;
u32 timeout = Timeout;
/* Poll on NOR memory Ready/Busy signal ------------------------------------*/
while((GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) != RESET) && (timeout > 0))
timeout--;
timeout = Timeout;
while((GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) == RESET) && (timeout > 0))
timeout--;
/* Get the NOR memory operation status -------------------------------------*/
while((Timeout != 0x00) && (status != NOR_SUCCESS))
Timeout--;
/* Read DQ6 and DQ5 */
val1 = *(vu16 *)(Bank1_NOR2_ADDR);
val2 = *(vu16 *)(Bank1_NOR2_ADDR);
/* If DQ6 did not toggle between the two reads then return NOR_Success */
if((val1 & 0x0040) == (val2 & 0x0040))
return NOR_SUCCESS;
if((val1 & 0x0020) != 0x0020)
return NOR_SUCCESS;
else if((val1 & 0x0020) == 0x0020)
return NOR_ERROR;
