因为要用内部FLASH代替外部EEPROM,把参数放在STM32的0x08000000+320K处,其中20K是bootloader,300K是应用程序。
原理:先要把整页FLASH的内容搬到RAM中,然后在RAM中改动,然后擦除整页FLASH,再把改动后的内容写入原Flash页。下面程序调试通过。
* Function Name : I2C_EE_BufferRead
* Description : Reads a block of data from the EEPROM.
* Input :
* -RomAddr
* -NumByteToRead
* -pRomData
* Output : None
* Return : None
void I2C_EE_BufferRead(u16 RomAddr,u16 NumByteToRead,u8 *pRomData)
u32 param_flashbase;
u8* ptr;
param_flashbase = 0x8000000+(300+20)*1024;
ptr = (u8*)(param_flashbase + RomAddr);
while( NumByteToRead-- >0)
*pRomData = *ptr; //直接赋值即可
printf("0x%x ",*pRomData);
pRomData++;
ptr++;
return;
* Function Name : I2C_EE_BufferWrite
* Description : Write a block of data to the EEPROM.
* Input :
* -RomAddr
* -NumByteToRead
* -pRomData
* Output : None
* Return : None
void I2C_EE_BufferWrite(u8 DeviceType,u8 SlaveAddr,u16 RomAddr,u16 NumByteToWrite,u8 *pRomData)
uint32_t param_flashbase;
uint32_t tempaddress;
uint32_t startaddress;
uint32_t FlashAddress;
uint32_t datasource;
u8 buf1[PAGE_SIZE];
u8 buf2[PAGE_SIZE];
u32 pagenumber = 0x0;
u32 EraseCounter = 0x0;
u32 i = 0;
FLASH_Status FLASHStatus = FLASH_COMPLETE;
startaddress=tempaddress = param_flashbase+RomAddr;
/*********************起始指针不在Flash页的开始端*********************
if( (tempaddress%PAGE_SIZE) != 0)
{ printf("startptr not in Page head \r\n");
if( ((startaddress%PAGE_SIZE)+NumByteToWrite) > PAGE_SIZE ) /*超出一页范围
I2C_EE_BufferRead(0,0,(tempaddress-(tempaddress % PAGE_SIZE)),PAGE_SIZE,buf1); /*把起始地址所在页的内容读到内存buf1中
memcpy(buf1+(tempaddress % PAGE_SIZE),pRomData,PAGE_SIZE-(tempaddress % PAGE_SIZE)); /*把需要写入的数据覆盖到buf1中
while( FLASHStatus == FLASH_ErasePage(tempaddress) ) /*buf1写入到Flash
i=PAGE_SIZE/4;
datasource = (uint32_t)buf1;
FlashAddress = tempaddress-(tempaddress % PAGE_SIZE);
while(i-- >0)
FLASH_ProgramWord(FlashAddress,*(uint32_t*)datasource);
if (*(uint32_t*)FlashAddress != *(uint32_t*)datasource)
printf("I2C_EE_BufferWrite error!\r\n");
return ;
datasource += 4;
FlashAddress += 4;
break;
NumByteToWrite -= PAGE_SIZE-(startaddress % PAGE_SIZE); 需要写入字节数减去,上面覆盖上去的数据的字节数
tempaddress += PAGE_SIZE-(tempaddress % PAGE_SIZE); /*把ptr指针指向下一个页起始位置
if((NumByteToWrite % PAGE_SIZE) != 0) /*末指针不在Flash页的开始端
//读取1 PAGE 数据到内存,修改,然后写进去
I2C_EE_BufferRead(0,0,tempaddress,PAGE_SIZE,buf2);
memcpy(buf2,pRomData+PAGE_SIZE-startaddress%PAGE_SIZE+NumByteToWrite-NumByteToWrite%PAGE_SIZE,(NumByteToWrite%PAGE_SIZE));
while( FLASHStatus == FLASH_ErasePage( tempaddress+NumByteToWrite) ) /*把buf2写入到Flash中*
i=PAGE_SIZE/4;
datasource = (uint32_t)buf2;
FlashAddress = (tempaddress+NumByteToWrite-(NumByteToWrite % PAGE_SIZE)); /*末地址指针的页首
while(i-- >0)
return ;
datasource += 4;
FlashAddress += 4;
break;
