#if OS_TIME_TICK_HOOK_EN > 0
OSTimeTickHook(); /* Call user definable hook */
#endif
#if OS_TIME_GET_SET_EN > 0
OS_ENTER_CRITICAL(); /* Update the 32-bit tick counter */
OSTime++;
OS_EXIT_CRITICAL();
#endif
if (OSRunning == OS_TRUE) {
ptcb = OSTCBList; /* Point at first TCB in TCB list */
while (ptcb->OSTCBPrio != OS_TASK_IDLE_PRIO) { /* Go through all TCBs in TCB list */
if (ptcb->OSTCBDly != 0) { /* No, Delayed or waiting for event with TO */
if (--ptcb->OSTCBDly == 0) { /* Decrement nbr of ticks to end of delay */
/* Check for timeout */
if ((ptcb->OSTCBStat & OS_STAT_PEND_ANY) != OS_STAT_RDY) {
ptcb->OSTCBStat &= ~(INT8U)OS_STAT_PEND_ANY; /* Yes, Clear status flag */
ptcb->OSTCBStatPend = OS_STAT_PEND_TO; /* Indicate PEND timeout */
} else {
ptcb->OSTCBStatPend = OS_STAT_PEND_OK;
if ((ptcb->OSTCBStat & OS_STAT_SUSPEND) == OS_STAT_RDY) { /* Is task suspended? */
OSRdyGrp |= ptcb->OSTCBBitY; /* No, Make ready */
OSRdyTbl[ptcb->OSTCBY] |= ptcb->OSTCBBitX;
ptcb = ptcb->OSTCBNext; /* Point at next TCB in TCB list */
OS_EXIT_CRITICAL();
上面的函数中主要做了俩件事情:
1:给计数器OSTime加1操作。
2:遍历任务TCB链表中的所有TCB,在任务的OSTCBDly不为0时,对OSTCBDly减1操作,当OSTCBDly为0并且此TCB没有挂起,
则使此任务进入就绪状态。
2:时间管理
void OSTimeDly (INT16U ticks)
INT8U y;
#if OS_CRITICAL_METHOD == 3 /* Allocate storage for CPU status register */
OS_CPU_SR cpu_sr = 0;
#endif
if (OSIntNesting > 0) { /* See if trying to call from an ISR */
return;
if (ticks > 0) { /* 0 means no delay! */
y = OSTCBCur->OSTCBY; /* Delay current task */
OSRdyTbl[y] &= ~OSTCBCur->OSTCBBitX;
if (OSRdyTbl[y] == 0) {
OSRdyGrp &= ~OSTCBCur->OSTCBBitY;
OSTCBCur->OSTCBDly = ticks; /* Load ticks in TCB */
OS_EXIT_CRITICAL();
OS_Sched(); /* Find next task to run! */
上面的代码ticks > 0满足时,是当前正在运行的任务延迟ticks,故使此任务从就绪表中移除。
取消任务的延时函数 |
