UCOS 时钟及时间管理(3)
UCOS 时钟及时间管理(3)
*                                         RESUME A DELAYED TASK
* Description: This function is used resume a task that has been delayed through a call to either
*              OSTimeDly() or OSTimeDlyHMSM().  Note that you can call this function to resume a
*              task that is waiting for an event with timeout.  This would make the task look
*              like a timeout occurred.
*              Also, you cannot resume a task that has called OSTimeDlyHMSM() with a combined time that
*              exceeds 65535 clock ticks.  In other words, if the clock tick runs at 100 Hz then, you will
*              not be able to resume a delayed task that called OSTimeDlyHMSM(0, 10, 55, 350) or higher:
*                  (10 Minutes * 60 + 55 Seconds + 0.35) * 100 ticks/second.
* Arguments  : prio                      specifies the priority of the task to resume
* Returns    : OS_ERR_NONE               Task has been resumed
*              OS_ERR_PRIO_INVALID       if the priority you specify is higher that the maximum allowed
*                                        (i.e. >= OS_LOWEST_PRIO)
*              OS_ERR_TIME_NOT_DLY       Task is not waiting for time to expire
*              OS_ERR_TASK_NOT_EXIST     The desired task has not been created or has been assigned to a Mutex.
#if OS_TIME_DLY_RESUME_EN > 0
INT8U  OSTimeDlyResume (INT8U prio)
    OS_TCB    *ptcb;
#if OS_CRITICAL_METHOD == 3                                    /* Storage for CPU status register      */
    OS_CPU_SR  cpu_sr = 0;
#endif
    if (prio >= OS_LOWEST_PRIO) {
        return (OS_ERR_PRIO_INVALID);
    OS_ENTER_CRITICAL();
    ptcb = OSTCBPrioTbl[prio];                                 /* Make sure that task exist            */
    if (ptcb == (OS_TCB *)0) {
        OS_EXIT_CRITICAL();
        return (OS_ERR_TASK_NOT_EXIST);                        /* The task does not exist              */
    if (ptcb == OS_TCB_RESERVED) {
        OS_EXIT_CRITICAL();
    if (ptcb->OSTCBDly == 0) {                                 /* See if task is delayed               */
        OS_EXIT_CRITICAL();
        return (OS_ERR_TIME_NOT_DLY);                          /* Indicate that task was not delayed   */
    ptcb->OSTCBDly = 0;                                        /* Clear the time delay                 */
    if ((ptcb->OSTCBStat & OS_STAT_PEND_ANY) != OS_STAT_RDY) {
        ptcb->OSTCBStat     &= ~OS_STAT_PEND_ANY;              /* Yes, Clear status flag               */
        ptcb->OSTCBStatPend  =  OS_STAT_PEND_TO;               /* Indicate PEND timeout                */
    } else {
        ptcb->OSTCBStatPend  =  OS_STAT_PEND_OK;
    if ((ptcb->OSTCBStat & OS_STAT_SUSPEND) == OS_STAT_RDY) {  /* Is task suspended?                   */
        OSRdyGrp               |= ptcb->OSTCBBitY;             /* No,  Make ready                      */
        OSRdyTbl[ptcb->OSTCBY] |= ptcb->OSTCBBitX;
        OS_EXIT_CRITICAL();
        OS_Sched();                                            /* See if this is new highest priority  */
    } else {
        OS_EXIT_CRITICAL();                                    /* Task may be suspended                */
    return (OS_ERR_NONE);
#endif
上面的代码前面是有效性判断,后面对prio优先级别的任务TCB的OSTCBDly=0操作,最后如果此 OSTCBPrioTbl[prio]任务没有挂起,则进行一个任务级别的任务切换操作OS_Sched()。
继承事业,薪火相传
