» 如何设置STM32内核异常优先级
如何设置STM32内核异常优先级
yuyang911220
286 小时
性别
男
yuyang911220
发表于 2015-5-25 21:30
如何设置STM32内核异常优先级
优先级
如何
* @brief Set the priority for an interrupt
* @param IRQn The number of the interrupt for set priority
* @param priority The priority to set
* Set the priority for the specified interrupt. The interrupt
* number can be positive to specify an external (device specific)
* interrupt, or negative to specify an internal (core) interrupt.
* Note: The priority cannot be set for every core interrupt.
static __INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
if(IRQn < 0) {
SCB->SHP[((uint32_t)(IRQn) & 0xF)-4] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff); } /* set Priority for Cortex-M3 System Interrupts */
else {
NVIC->IP[(uint32_t)(IRQn)] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff);} /* set Priority for device specific Interrupts */
对于使用cm3内核的stm32来说,中断既包括内核异常也包括外设中断。以上代码用来设置中断优先级,代码来自3.5外设库中的core_cm3.h文件。可以对内核中断进行配置,也可以对外设进行中断优先级配置。对内和和外设中断优先级设置的寄存器不同,内核对应的是SHPRx寄存器组,而外设对应的是NVIC_IPRx寄存器组。
SYSTICK使用core_cm3.h文件进行配置时,默认的优先级配置为15,最低优先级。
[cpp]
view plain
copy
NVIC_SetPriority (SysTick_IRQn, (1<<__NVIC_PRIO_BITS) - 1); //NVIC_PRIO_BITS为常数4 (1<<4-1 = 15)优先级最低。
[cpp]
view plain
copy
* @brief Initialize and start the SysTick counter and its interrupt.
* @param ticks number of ticks between two interrupts
* @return 1 = failed, 0 = successful
* Initialise the system tick timer and its interrupt and start the
* system tick timer / counter in free running mode to generate
* periodical interrupts.
static __INLINE uint32_t SysTick_Config(uint32_t ticks)
if (ticks > SysTick_LOAD_RELOAD_Msk) return (1); /* Reload value impossible */
SysTick->LOAD = (ticks & SysTick_LOAD_RELOAD_Msk) - 1; /* set reload register */
NVIC_SetPriority (SysTick_IRQn, (1<<__NVIC_PRIO_BITS) - 1); /* set Priority for Cortex-M0 System Interrupts */
SysTick->VAL = 0; /* Load the SysTick Counter Value */
SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk |
SysTick_CTRL_TICKINT_Msk |
SysTick_CTRL_ENABLE_Msk; /* Enable SysTick IRQ and SysTick Timer */
return (0); /* Function successful */
继承事业,薪火相传
