我做的毕业设计是16位全加器的分析与设计,源程序已经写好了,用quartus软件检查过已经没错了,但就是不知道怎么可以仿真出波形来,希望高手帮忙/ 最好能说明一下怎么看出毛刺,和怎么消除,谢谢了 源程序" LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY ADDER4 IS PORT(C4: IN STD_LOGIC; A4: IN STD_LOGIC_VECTOR(3 DOWNTO 0); B4: IN STD_LOGIC_VECTOR(3 DOWNTO 0); S4: OUT STD_LOGIC_VECTOR(3 DOWNTO 0); CO4: OUT STD_LOGIC); END ENTITY ADDER4; ARCHITECTURE ART OF ADDER4 IS SIGNAL S5: STD_LOGIC_VECTOR(4 DOWNTO 0); SIGNAL A5, B5: STD_LOGIC_VECTOR(4 DOWNTO 0); BEGIN A5<='0'& A4; B5<='0'& B4; S5<=A5+B5+C4; S4<=S5(3 DOWNTO 0); CO4<=S5(4); END ARCHITECTURE ART; LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY ADDER16 IS --由4位二进制并行加法器级联而成的16位二进制加法器 PORT(C16: IN STD_LOGIC; A16: IN STD_LOGIC_VECTOR(15 DOWNTO 0); B16: IN STD_LOGIC_VECTOR(15 DOWNTO 0); S16: OUT STD_LOGIC_VECTOR(15 DOWNTO 0); CO16: OUT STD_LOGIC); END ENTITY ADDER16; ARCHITECTURE ART OF ADDER16 IS COMPONENT ADDER4 IS --对要调用的元件ADDER4B的界面端口进行定义 PORT(C4: IN STD_LOGIC; A4: IN STD_LOGIC_VECTOR(3 DOWNTO 0); B4: IN STD_LOGIC_VECTOR(3 DOWNTO 0); S4: OUT STD_LOGIC_VECTOR(3 DOWNTO 0); CO4: OUT STD_LOGIC); END COMPONENT ADDER4; SIGNAL SC1, SC2, SC3: STD_LOGIC; --4位加法器的进位标志 BEGIN U1: ADDER4 --例化(安装)一个4位二进制加法器U1 PORT MAP(C4=>C16, A4=>A16(3 DOWNTO 0), B4=>B16(3 DOWNTO 0), S4=>S16(3 DOWNTO 0), CO4=>SC1); U2: ADDER4 --例化(安装)一个4位二进制加法器U2 PORT MAP(C4=>SC1, A4=>A16(7 DOWNTO 4), B4=>B16(7 DOWNTO 4), S4=>S16 (7 DOWNTO 4), CO4=>SC2); U3: ADDER4 --例化(安装)一个4位二进制加法器U1 PORT MAP(C4=>SC2, A4=>A16(11 DOWNTO 8), B4=>B16(11 DOWNTO 8), S4=>S16(11 DOWNTO 8), CO4=>SC3); U4: ADDER4 --例化(安装)一个4位二进制加法器U1 PORT MAP(C4=>SC3, A4=>A16(15 DOWNTO 12), B4=>B16(15 DOWNTO 12), S4=>S16(15 DOWNTO 12), CO4=>CO16); END ARCHITECTURE ART;
