μcosii源码试读3- OS_InitTCBList();任务控制块链表初始化及其功能(3)
  •     OS_FLAG_NODE *OSTCBFlagNode; /* Pointer to event flag node */
  • #endif
  •     OS_FLAGS OSTCBFlagsRdy; /* Event flags that made task ready to run */
  • #endif
  •     INT16U OSTCBDly; /* Nbr ticks to delay task or, timeout waiting for event */
  •     INT8U OSTCBStat; /* Task status */
  •     BOOLEAN OSTCBPendTO; /* Flag indicating PEND timed out (OS_TRUE == timed out) */
  •     INT8U OSTCBPrio; /* Task priority (0 == highest) */
  •     INT8U OSTCBX; /* Bit position in group corresponding to task priority */
  •     INT8U OSTCBY; /* Index into ready table corresponding to task priority */
  • #if OS_LOWEST_PRIO <= 63
  •     INT8U OSTCBBitX; /* Bit mask to access bit position in ready table */
  •     INT8U OSTCBBitY; /* Bit mask to access bit position in ready group */
  • #else
  •     INT16U OSTCBBitX; /* Bit mask to access bit position in ready table */
  •     INT16U OSTCBBitY; /* Bit mask to access bit position in ready group */
  • #endif
  • #if OS_TASK_DEL_EN > 0
  •     INT8U OSTCBDelReq; /* Indicates whether a task needs to delete itself */
  • #endif
  • #if OS_TASK_PROFILE_EN > 0
  •     INT32U OSTCBCtxSwCtr; /* Number of time the task was switched in */
  •     INT32U OSTCBCyclesTot; /* Total number of clock cycles the task has been running */
  •     INT32U OSTCBCyclesStart; /* Snapshot of cycle counter at start of task resumption */
  •     OS_STK *OSTCBStkBase; /* Pointer to the beginning of the task stack */
  •     INT32U OSTCBStkUsed; /* Number of bytes used from the stack */
  • #endif
  • #if OS_TASK_NAME_SIZE > 1
  •     INT8U OSTCBTaskName[OS_TASK_NAME_SIZE];
  • #endif
  • } OS_TCB;
OSTCBStkPtr 指向任务堆栈顶端的指针 栈的元素大小为32位宽
当允许使用OSTaskCreatExt()时即OS_TASK_CREATE_EXT_EN被置为1时可用:
void * OSTCBExtPtr 使用系统调用OSTaskCreatExt()创建的用户自定义数据段
OSTCBStkBottom 指向栈底的指针,系统调用OSTaskStkChk()来检测运行中堆栈的情况
OSTCBStkSize 存储栈所能容纳的指针元素,如果一个指针是32位,则有栈的大小为本数*4个字节
OSTCBOpt选择项用来告诉TaskCreatExt()在任务建立的时候任务栈检验功能得到了允许,
OSTCBNext OSTCBPrev 构成双链表的双向指针,指向上一个或者下一个TCB数据结构,构成了一个双向非循环链表
OSTCBEventPtr 指向事件控制数据块 用于任务间的通信和同步
OSTCBTaskName存任务名的数组,其中第一个数据[0]存入'?'
OSTCBList是一个指向TCB双链表表头的指针,初始化中赋值为NULL指针,之后创建task时加入TCB双链表
OSTCBFreeList空任务控制块指针,指向由空任务组成的链表,当一个任务建立时,将头指针指向的任务块交给该任务使用,当任务删除时,任务把任务块交还给空任务链表。
OSTCBTbl[]存放所有任务块的数组,不论是空任务块还是非空任务块,都在这个数组中,在不同的链表中组织结构不同
OSTCBPrioTbl[]指针数组 每一个元素都指向TCB
总结:这个初始化函数初始化了TCB数组和链表,TCB结构的初始化在建立新task时才会用到
继承事业,薪火相传
