三、例程:STM32读写外NOR FLASH 存储器 39VF1601
1. fsmc_nor..c
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : fsmc_nor.c
* Author : MCD Application Team
* Version : V2.0.1
* Date : 06/13/2008
* Description : This file provides a set of functions needed to drive the
* M29W128FL, M29W128GL and S29GL128P NOR memories mounted
* on STM3210E-EVAL board.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "fsmc_nor.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define Bank1_NOR2_ADDR ((u32)0x64000000)
/* Delay definition */
#define BlockErase_Timeout ((u32)0x00A00000)
#define ChipErase_Timeout ((u32)0x30000000)
#define Program_Timeout ((u32)0x00001400)
/* Private macro -------------------------------------------------------------*/
#define ADDR_SHIFT(A) (Bank1_NOR2_ADDR + (2 * (A)))
#define NOR_WRITE(Address, Data) (*(vu16 *)(Address) = (Data))
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name : FSMC_NOR_Init
* Description : Configures the FSMC and GPIOs to interface with the NOR memory.
* This function must be called before any write/read operation
* on the NOR.
* Input : None
* Output : None
* Return : None
void FSMC_NOR_Init(void)
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef p;
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
/*-- GPIO Configuration ------------------------------------------------------*/
/* NOR Data lines configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 |
GPIO_Init(GPIOE, &GPIO_InitStructure); |
