STM32-FSMC-NOR FLASH(5)
* Function Name  : FSMC_NOR_ReadID
* Description    : Reads NOR memory's Manufacturer and Device Code.
* Input          : - NOR_ID: pointer to a NOR_IDTypeDef structure which will hold
*                    the Manufacturer and Device Code.
* Output         : None
* Return         : None
void FSMC_NOR_ReadID(NOR_IDTypeDef* NOR_ID)
  NOR_WRITE(ADDR_SHIFT(0x05555), 0x00AA);
  NOR_WRITE(ADDR_SHIFT(0x02AAA), 0x0055);
  NOR_WRITE(ADDR_SHIFT(0x05555), 0x0090);
  NOR_ID->Manufacturer_Code = *(vu16 *) ADDR_SHIFT(0x0000);
  NOR_ID->Device_Code1 = *(vu16 *) ADDR_SHIFT(0x0001);
  NOR_ID->Device_Code2 = *(vu16 *) ADDR_SHIFT(0x000E);
  NOR_ID->Device_Code3 = *(vu16 *) ADDR_SHIFT(0x000F);
* Function Name  : FSMC_NOR_EraseBlock
* Description    : Erases the specified Nor memory block.
* Input          : - BlockAddr: address of the block to erase.
* Output         : None
* Return         : NOR_Status:The returned value can be: NOR_SUCCESS, NOR_ERROR
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_EraseBlock(u32 BlockAddr)
  NOR_WRITE(ADDR_SHIFT(0x05555), 0x0080);
  NOR_WRITE((Bank1_NOR2_ADDR + BlockAddr), 0x30);
  return (FSMC_NOR_GetStatus(BlockErase_Timeout));
* Function Name  : FSMC_NOR_EraseChip
* Description    : Erases the entire chip.
* Input          : None
* Output         : None
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_EraseChip(void)
  NOR_WRITE(ADDR_SHIFT(0x05555), 0x0010);
  return (FSMC_NOR_GetStatus(ChipErase_Timeout));
* Function Name  : FSMC_NOR_WriteHalfWord
* Description    : Writes a half-word to the NOR memory.
* Input          : - WriteAddr : NOR memory internal address to write to.
*                  - Data : Data to write.
* Output         : None
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_WriteHalfWord(u32 WriteAddr, u16 Data)
  NOR_WRITE(ADDR_SHIFT(0x05555), 0x00A0);
  NOR_WRITE((Bank1_NOR2_ADDR + WriteAddr), Data);
  return (FSMC_NOR_GetStatus(Program_Timeout));
继承事业,薪火相传
