* Function Name : FSMC_NOR_WriteBuffer
* Description : Writes a half-word buffer to the FSMC NOR memory.
* Input : - pBuffer : pointer to buffer.
* - WriteAddr : NOR memory internal address from which the data
* will be written.
* - NumHalfwordToWrite : number of Half words to write.
* Output : None
* Return : NOR_Status:The returned value can be: NOR_SUCCESS, NOR_ERROR
* or NOR_TIMEOUT
NOR_Status FSMC_NOR_WriteBuffer(u16* pBuffer, u32 WriteAddr, u32 NumHalfwordToWrite)
NOR_Status status = NOR_ONGOING;
do
/* Transfer data to the memory */
status = FSMC_NOR_WriteHalfWord(WriteAddr, *pBuffer++);
WriteAddr = WriteAddr + 2;
NumHalfwordToWrite--;
while((status == NOR_SUCCESS) && (NumHalfwordToWrite != 0));
return (status);
* Function Name : FSMC_NOR_ProgramBuffer
* Description : Writes a half-word buffer to the FSMC NOR memory. This function
* must be used only with S29GL128P NOR memory.
* - WriteAddr: NOR memory internal address from which the data
* will be written.
* - NumHalfwordToWrite: number of Half words to write.
* The maximum allowed value is 32 Half words (64 bytes).
* Output : None
* or NOR_TIMEOUT
NOR_Status FSMC_NOR_ProgramBuffer(u16* pBuffer, u32 WriteAddr, u32 NumHalfwordToWrite)
u32 lastloadedaddress = 0x00;
u32 currentaddress = 0x00;
u32 endaddress = 0x00;
/* Initialize variables */
currentaddress = WriteAddr;
endaddress = WriteAddr + NumHalfwordToWrite - 1;
lastloadedaddress = WriteAddr;
/* Issue unlock command sequence */
NOR_WRITE(ADDR_SHIFT(0x005555), 0x00AA);
NOR_WRITE(ADDR_SHIFT(0x02AAA), 0x0055);
/* Write Write Buffer Load Command */
NOR_WRITE(ADDR_SHIFT(WriteAddr), 0x0025);
NOR_WRITE(ADDR_SHIFT(WriteAddr), (NumHalfwordToWrite - 1));
/* Load Data into NOR Buffer */
while(currentaddress <= endaddress)
/* Store last loaded address & data value (for polling) */
lastloadedaddress = currentaddress;
NOR_WRITE(ADDR_SHIFT(currentaddress), *pBuffer++);
currentaddress += 1;
NOR_WRITE(ADDR_SHIFT(lastloadedaddress), 0x29);
return(FSMC_NOR_GetStatus(Program_Timeout));
* Function Name : FSMC_NOR_ReadHalfWord
* Description : Reads a half-word from the NOR memory.
* Input : - ReadAddr : NOR memory internal address to read from.
* Output : None
* Return : Half-word read from the NOR memory
u16 FSMC_NOR_ReadHalfWord(u32 ReadAddr)
NOR_WRITE(ADDR_SHIFT(0x002AAA), 0x0055);
NOR_WRITE((Bank1_NOR2_ADDR + ReadAddr), 0x00F0 );
return (*(vu16 *)((Bank1_NOR2_ADDR + ReadAddr)));
* Function Name : FSMC_NOR_ReadBuffer
* Description : Reads a block of data from the FSMC NOR memory.
* Input : - pBuffer : pointer to the buffer that receives the data read
* from the NOR memory.
* - ReadAddr : NOR memory internal address to read from.
* - NumHalfwordToRead : number of Half word to read.
* Output : None
* Return : None
void FSMC_NOR_ReadBuffer(u16* pBuffer, u32 ReadAddr, u32 NumHalfwordToRead)
NOR_WRITE(ADDR_SHIFT(0x05555), 0x00AA);
NOR_WRITE((Bank1_NOR2_ADDR + ReadAddr), 0x00F0);
for(; NumHalfwordToRead != 0x00; NumHalfwordToRead--) /* while there is data to read */
/* Read a Halfword from the NOR */
*pBuffer++ = *(vu16 *)((Bank1_NOR2_ADDR + ReadAddr));
ReadAddr = ReadAddr + 2;
