val1 = *(vu16 *)(Bank1_NOR2_ADDR);
val2 = *(vu16 *)(Bank1_NOR2_ADDR);
if((val1 & 0x0040) == (val2 & 0x0040))
return NOR_SUCCESS;
else if((val1 & 0x0020) == 0x0020)
return NOR_ERROR;
} if(Timeout == 0x00)
status = NOR_TIMEOUT;
/* Return the operation status */
return (status);
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
2.main.c
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Version : V2.0.1
* Date : 06/13/2008
* Description : Main program body
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "fsmc_nor.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define BUFFER_SIZE 0x400
#define WRITE_READ_ADDR 0x8000
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef GPIO_InitStructure;
ErrorStatus HSEStartUpStatus;
u16 TxBuffer[BUFFER_SIZE];
u16 RxBuffer[BUFFER_SIZE];
u32 WriteReadStatus = 0, Index = 0;
NOR_IDTypeDef NOR_ID;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Fill_Buffer(u16 *pBuffer, u16 BufferLenght, u32 Offset);
/* Private functions ---------------------------------------------------------*/
* Function Name : main
* Description : Main program.
* Input : None
* Output : None
* Return : None
