int main(void)
#ifdef DEBUG
debug();
#endif /* System Clocks Configuration */
RCC_Configuration();
/* NVIC Configuration */
NVIC_Configuration();
/* PF.06 and PF.07 config to drive LD1 and LD2 *****************************/
/* Enable GPIOF clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE);
/* Configure PF.06 and PF.07 as Output push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOF, &GPIO_InitStructure);
/* Write/read to/from FSMC SRAM memory *************************************/
/* Enable the FSMC Clock */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
/* Configure FSMC Bank1 NOR/SRAM2 */
FSMC_NOR_Init();
/* Read NOR memory ID */
FSMC_NOR_ReadID(&NOR_ID);
FSMC_NOR_ReturnToReadMode();
/* Erase the NOR memory block to write on */
FSMC_NOR_EraseBlock(WRITE_READ_ADDR);
/* Write data to FSMC NOR memory */
/* Fill the buffer to send */
Fill_Buffer(TxBuffer, BUFFER_SIZE, 0x3210);
FSMC_NOR_WriteBuffer(TxBuffer, WRITE_READ_ADDR, BUFFER_SIZE);
/* Read data from FSMC NOR memory */
FSMC_NOR_ReadBuffer(RxBuffer, WRITE_READ_ADDR, BUFFER_SIZE);
/* Read back NOR memory and check content correctness */
for (Index = 0x00; (Index < BUFFER_SIZE) && (WriteReadStatus == 0); Index++)
if (RxBuffer[Index] != TxBuffer[Index])
WriteReadStatus = Index + 1;
