STM32-FSMC-NOR FLASH(11)
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
void NVIC_Configuration(void)
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
* Function name : Fill_Buffer
* Description   : Fill the global buffer
* Input         : - pBuffer: pointer on the Buffer to fill
*                 - BufferSize: size of the buffer to fill
*                 - Offset: first value to fill on the Buffer
* Output param  : None
void Fill_Buffer(u16 *pBuffer, u16 BufferLenght, u32 Offset)
  u16 IndexTmp = 0;
  /* Put in global buffer same values */
  for (IndexTmp = 0; IndexTmp < BufferLenght; IndexTmp++ )
    pBuffer[IndexTmp] = IndexTmp + Offset;
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d/r/n", file, line) */
  /* Infinite loop */
  while (1)
#endif
继承事业,薪火相传
