ARM做为USB从设备的实现(2)
ARM做为USB从设备的实现(2)
2, 在linux-2.6.31.1-cavm1/drivers/usb/gadget中,hid.c文件写法有误.
正确写法为:
[cpp] view plaincopy
  • * hid.c -- HID Composite driver
  • * Based on multi.c
  • * Copyright (C) 2010 Fabien Chouteau <fabien.chouteau@barco.com>
  • * This program is free software; you can redistribute it and/or modify
  • * it under the terms of the GNU General Public License as published by
  • * the Free Software Foundation; either version 2 of the License, or
  • * (at your option) any later version.
  • * This program is distributed in the hope that it will be useful,
  • * but WITHOUT ANY WARRANTY; without even the implied warranty of
  • * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  • * GNU General Public License for more details.
  • * You should have received a copy of the GNU General Public License
  • * along with this program; if not, write to the Free Software
  • * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
  • #include <linux/kernel.h>
  • #include <linux/platform_device.h>
  • #include <linux/list.h>
  • #include <linux/usb/musb.h>
  • #define DRIVER_DESC     "HID ps3 controller"
  • #define DRIVER_VERSION      "2011/07/21"
  • #define HIDG_VENDOR_NUM     0x0525  /* XXX NetChip */
  • #define HIDG_PRODUCT_NUM    0xa4ac  /* Linux-USB HID gadget */
  • * kbuild is not very cooperative with respect to linking separately
  • * compiled library objects into one module.  So for now we won't use
  • * separate compilation ... ensuring init/exit sections work to shrink
  • * the runtime footprint, and giving us at least some parts of what
  • * a "gcc --combine ... part1.c part2.c part3.c ... " build would.
  • #include "composite.c"
  • #include "usbstring.c"
  • #include "config.c"
  • #include "epautoconf.c"
  • #include "f_hid.c"
  • struct hidg_func_node {
  •     struct list_head node;
  •     struct hidg_func_descriptor *func;
  • static LIST_HEAD(hidg_func_list);
  • static
    struct usb_device_descriptor device_desc = {
  •     .bLength =      sizeof device_desc,
  •     .bDescriptorType =  USB_DT_DEVICE,
  •     .bcdUSB =       cpu_to_le16(0x0200),
  •     /* .bDeviceClass =      USB_CLASS_COMM, */
  •     /* .bDeviceSubClass =   0, */
  •     /* .bDeviceProtocol =   0, */
  •     .bDeviceClass =     0xEF,
  •     .bDeviceSubClass =  2,
  •     .bDeviceProtocol =  1,
  •     /* .bMaxPacketSize0 = f(hardware) */
  •     /* Vendor and product id can be overridden by module parameters.  */
  •     .idVendor =     cpu_to_le16(HIDG_VENDOR_NUM),
  •     .idProduct =        cpu_to_le16(HIDG_PRODUCT_NUM),
  •     /* .bcdDevice = f(hardware) */
  •     /* .iManufacturer = DYNAMIC */
  •     /* .iProduct = DYNAMIC */
  •     /* NO SERIAL NUMBER */
  •     .bNumConfigurations =   1,
  • static
    struct usb_otg_descriptor otg_descriptor = {
  •     .bLength =      sizeof otg_descriptor,
  •     .bDescriptorType =  USB_DT_OTG,
  •     /* REVISIT SRP-only hardware is possible, although
  •      * it would not be called "OTG" ...
  •     .bmAttributes =     USB_OTG_SRP | USB_OTG_HNP,
  • static
    const
    struct usb_descriptor_header *otg_desc[] = {
  •     (struct usb_descriptor_header *) &otg_descriptor,
  •     NULL,
  • /* string IDs are assigned dynamically */
  • #define STRING_MANUFACTURER_IDX     0
  • #define STRING_PRODUCT_IDX      1
  • static
    char manufacturer[50];
  • static
    struct usb_string strings_dev[] = {
  •     [STRING_MANUFACTURER_IDX].s = manufacturer,
  •     [STRING_PRODUCT_IDX].s = DRIVER_DESC,
  •     {  } /* end of list */
  • static
    struct usb_gadget_strings stringtab_dev = {
  •     .language   = 0x0409,   /* en-us */
  •     .strings    = strings_dev,
  • static
    struct usb_gadget_strings *dev_strings[] = {
  •     &stringtab_dev,
  •     NULL,
  • /****************************** Configurations ******************************/
  • static
    int __init do_config(struct usb_configuration *c)
  •     struct hidg_func_node *e;
  •     int func = 0, status = 0;
  •     if (gadget_is_otg(c->cdev->gadget)) {
  •         c->descriptors = otg_desc;
  •         c->bmAttributes |= USB_CONFIG_ATT_WAKEUP;
  •     list_for_each_entry(e, &hidg_func_list, node) {
  •         status = hidg_bind_config(c, e->func, func++);
  •         if (status)
  •             break;
  •     return status;
  • static
    struct usb_configuration config_driver = {
  •     .label          = "HID Gadget",
  •     .bind           = do_config,
  •     .bConfigurationValue    = 1,
  •     /* .iConfiguration = DYNAMIC */
  •     .bmAttributes       = USB_CONFIG_ATT_SELFPOWER,
继承事业,薪火相传
