ARM做为USB从设备的实现(3)
ARM做为USB从设备的实现(3)
  • /****************************** Gadget Bind ******************************/
  • static
    int __init hid_bind(struct usb_composite_dev *cdev)
  •     struct usb_gadget *gadget = cdev->gadget;
  •     struct list_head *tmp;
  •     int status, gcnum, funcs = 0;
  •     list_for_each(tmp, &hidg_func_list)
  •         funcs++;
  •     if (!funcs)
  •         return -ENODEV;
  •     /* set up HID */
  •     printk("=============bind\n");
  •     status = ghid_setup(cdev->gadget, funcs);
  •     if (status < 0)
  •         return status;
  •     gcnum = usb_gadget_controller_number(gadget);
  •     if (gcnum >= 0)
  •         device_desc.bcdDevice = cpu_to_le16(0x0300 | gcnum);
  •     else
  •         device_desc.bcdDevice = cpu_to_le16(0x0300 | 0x0099);
  •     /* Allocate string descriptor numbers ... note that string
  •      * contents can be overridden by the composite_dev glue.
  •     /* device descriptor strings: manufacturer, product */
  •     snprintf(manufacturer, sizeof manufacturer, "%s %s with %s",
  •         init_utsname()->sysname, init_utsname()->release,
  •         gadget->name);
  •     status = usb_string_id(cdev);
  •     if (status < 0)
  •         return status;
  •     strings_dev[STRING_MANUFACTURER_IDX].id = status;
  •     device_desc.iManufacturer = status;
  •     if (status < 0)
  •         return status;
  •     strings_dev[STRING_PRODUCT_IDX].id = status;
  •     device_desc.iProduct = status;
  •     /* register our configuration */
  •     status = usb_add_config(cdev, &config_driver);
  •     if (status < 0)
  •         return status;
  •     dev_info(&gadget->dev, DRIVER_DESC ", version: " DRIVER_VERSION "\n");
  •     return 0;
  • static
    int __exit hid_unbind(struct usb_composite_dev *cdev)
  •     ghid_cleanup();
  •     return 0;
  • static
    int __init hidg_plat_driver_probe(struct platform_device *pdev)
  •     struct hidg_func_descriptor *func = pdev->dev.platform_data;
  •     struct hidg_func_node *entry;
  •     if (!func) {
  •         dev_err(&pdev->dev, "Platform data missing\n");
  •         return -ENODEV;
  •     entry = kzalloc(sizeof(*entry), GFP_KERNEL);
  •     if (!entry)
  •         return -ENOMEM;
  •     entry->func = func;
  •     list_add_tail(&entry->node, &hidg_func_list);
  •     return 0;
  • static
    int __devexit hidg_plat_driver_remove(struct platform_device *pdev)
  •     struct hidg_func_node *e, *n;
  •     list_for_each_entry_safe(e, n, &hidg_func_list, node) {
  •         list_del(&e->node);
  •         kfree(e);
  •     return 0;
  • /****************************** Some noise ******************************/
  • static
    struct usb_composite_driver hidg_driver = {
  •     .name       = "g_hid",
  •     .dev        = &device_desc,
  •     .strings    = dev_strings,
  •     .bind       = hid_bind,
  •     .unbind     = __exit_p(hid_unbind),
  • static
    struct platform_driver hidg_plat_driver = {
  •     .remove     = __devexit_p(hidg_plat_driver_remove),
  •     .driver     = {
  •         .name   = "hidg",
  •         .owner  = THIS_MODULE,
  • static
    struct musb_hdrc_platform_data hidg_plat_data = {
  •     .mode       = MUSB_PERIPHERAL,//MUSB_OTG,
  • static
    struct platform_device hidg_plat_device = {
  •     .name       = "hidg",
  •     .id         = -1,
  •     .dev        = {
  •         //.init_name = "hidg_init"
  •         .platform_data  = &hidg_plat_data,
  • MODULE_DESCRIPTION(DRIVER_DESC);
  • MODULE_AUTHOR("Fabien Chouteau, Peter Korsgaard");
  • MODULE_LICENSE("GPL");
  • static
    int __init hidg_init(void)
  •     int status;
  •     status = platform_device_register(&hidg_plat_device);
  •     if(status < 0)
  •         return status;
  •     status = platform_driver_probe(&hidg_plat_driver, hidg_plat_driver_probe);
  •     if (status < 0)
  •         return status;
  •     status = usb_composite_register(&hidg_driver);
  •     if (status < 0)
  •         platform_driver_unregister(&hidg_plat_driver);
  •     return status;
  • module_init(hidg_init);
  • static
    void __exit hidg_cleanup(void)
  •     usb_composite_unregister(&hidg_driver);
  • module_exit(hidg_cleanup);
继承事业,薪火相传
