void start_armboot (void)
DECLARE_GLOBAL_DATA_PTR;
//此宏定义了一个gd_t类型的指针 *gd,并指名用r8寄存器来存储:
#define DECLARE_GLOBAL_DATA_PTR register volatile gd_t *gd asm("r8")
ulong size;
init_fnc_t **init_fnc_ptr;
char *s;
gd = (gd_t*)(_armboot_start - CFG_MALLOC_LEN -sizeof(gd_t));
此C语句引用的是start.S中的地址标号_armboot_start,但是得到的却是其中所指的变量_start的值(在RAM中,_start
= 0x33F80000)。 Ps: _armboot_start: .word_start
//gd是全局变量,位置在堆栈区以下(低地址):
typedef struct global_data {
bd_t *bd;
unsigned long flags;
unsigned long baudrate;
unsigned longhave_console;
unsigned long reloc_off;
unsigned long env_addr;
unsigned longenv_valid;
unsigned long fb_base;
#ifdef CONFIG_VFD
unsigned char vfd_type;
#endif
#if 0
unsigned long cpu_clk;
unsigned long bus_clk;
unsigned long ram_size;
unsigned longreset_status;
#endif
void **jt;
} gd_t;
__asm__ __volatile__("": : :"memory");
memset ((void*)gd, 0, sizeof (gd_t));
gd->bd = (bd_t*)((char*)gd -sizeof(bd_t)); //得到bd的起点
memset (gd->bd, 0, sizeof(bd_t));
monitor_flash_len = _bss_start -_armboot_start;
for (init_fnc_ptr = init_sequence;*init_fnc_ptr; ++init_fnc_ptr) {
if((*init_fnc_ptr)() != 0) {
hang();
size = flash_init (); //初始化Norflash的函数,函数实现在下面
display_flash_config (size); //打印到控制台:Flash: 512 kB
mem_malloc_init (_armboot_start -CFG_MALLOC_LEN); //将CFG_MALLOC_LEN区域用memset函数清零(直接往目的地址写0)
env_relocate (); //刚才的初始化函数中有一个是env_init(),根据CRC校验来初始化gd->env_addr变量(自己设定的还是初始值),此函数是作用是将环境变量值从某个flash和RAM之间的拷贝。下图描述了ENV的初始化过程:
gd->bd->bi_ip_addr= getenv_IPaddr ("ipaddr");
int i;
ulongreg;
char *s,*e;
uchartmp[64];
i = getenv_r("ethaddr", tmp, sizeof (tmp));
s = (i> 0) ? tmp : NULL;
for (reg = 0;reg 6; ++reg) {
gd->bd->bi_enetaddr[reg]= s ? simple_strtoul (s, &e, 16) : 0;
if (s)
s = (*e) ?e + 1 : e;
devices_init ();
jumptable_init ();
console_init_r ();
enable_interrupts ();
if ((s = getenv ("loadaddr")) != NULL) {
load_addr =simple_strtoul (s, NULL, 16);
for (;;) {
main_loop();
