ARM的BUS Matrix就是多主(Core,DMA等),多从(内部RAM,APB,外部总线等)的交联和仲裁。目的是为了提高不同主机访问不同外设情况下的带宽,另外一个就是简化Bus Master的协议设计。
比如,DMA把片内RAM的数据搬运到APB的外设,如串行口。同时Core从外部总线,SDRAM取指令。如果单一总线,那么Core和DMA控制器就需要先仲裁总线控制权,然后才能访问对应的外设,此时单一总线的带宽不一定够。如果用交联矩阵,那么Core可以直接访问SDRAM,同时DMA访问APB外设。
如果没有用到多个BUS Master,典型如DMA,LCD控制器等都没有用到,具体看芯片,那么Matrix不会有什么性能提升;当然,如果用到了多个Slave,可能会有少量的性能损失,切换总线节点可能需要比直接仲裁更多的时间;(仲裁完成-传输数据 vs 仲裁完成-切换/保持总线节点-传输数据)
如果只用了一个Slave,比如Core,DMA,LCD都是只访问外部总线的SDRAM,实质上就是多主单从结构,效率或许会下降。
Bus matrix
The bus matrix connects the processor and debug interface to theexternal buses. The bus matrix interfaces to the following externalbuses:
- ICode bus. This is for instruction and vector fetches from codespace. This is a 32-bit AHB-Lite bus.
- DCode bus. This is for data load/stores and debug accesses tocode space. This is a 32-bit AHB-Lite bus.
- System bus. This is for instruction and vector fetches, dataload/stores and debug accesses to system space. This is a 32-bitAHB-Lite bus.
- PPB. This is for data load/stores and debug accesses to PPBspace. This is a 32-bit APB (v3.0) bus.
The bus matrix also controls the following:
- Unaligned accesses. The bus matrix converts unaligned processoraccesses into aligned accesses.
- Bit-banding. The bus matrix converts bit-band alias accessesinto bit-band region accesses. It performs:
- bit field extract for bit-band loads
- atomic read-modify-write for bit-band stores.
- Write buffering. The bus matrix contains a one-entry writebuffer to decouple bus stalls from the processor core.
