嵌入式系统中的FLASH(4)
嵌入式系统中的FLASH(4)
5)      NAND 的读操作
static int NF_ReadPage(U32 block,U32 page,U8 *buffer)       //读Flash
    int i;
    unsigned int blockPage;
    U8 ecc0,ecc1,ecc2;
    U8 *bufPt=buffer;
    U8 se[16];
    page=page&0x1f;                                 //32页
    blockPage=(block                      //1Bolck包含32页
    NF_RSTECC();                                    // Initialize ECC
    NF_nFCE_L();
    NF_CMD(0x00);                                   // Read command
    NF_ADDR(0);                                     // Column = 0
    NF_ADDR(blockPage&0xff);                        //
    NF_ADDR((blockPage>>8)&0xff);                   // Block & Page num.
  NF_ADDR((blockPage>>16)&0xff);                 //
    for(i=0;i                             //wait tWB(100ns)
    NF_WAITRB();                                    // Wait tR(max 12us)
    for(i=0;i
        *bufPt++=NF_RDDATA();                       // Read one page
/************************ECC校验***************************/
   ecc0=rNFECC0;                              //利用2410自带的硬件ECC校验
    ecc1=rNFECC1;
    ecc2=rNFECC2;
[q3]
     for(i=0;i
        se=NF_RDDATA();                         // Read spare array
                                                    //读页内冗余的16B
       NF_nFCE_H();
    if(ecc0==se[0] && ecc1==se[1] && ecc2==se[2])   //未知使用哪一种软件规范?
    {                                               //比较数据结果是否正确
    Uart_Printf("[ECC OK:%x,%x,%x]\n",se[0],se[1],se[2]);
        return 1;
    else
    Uart_Printf("[ECC ERROR(RD):read:%x,%x,%x, reg:%x,%x,%x]\n",
        se[0],se[1],se[2],ecc0,ecc1,ecc2);
        return 0;
6)      NAND 的写操作
static int NF_WritePage(U32 block,U32 page,U8 *buffer)             //写Flash
    int i;
    U32 blockPage=(block
    U8 *bufPt=buffer;
    NF_nFCE_L();
    NF_CMD(0x0
[q4]
);                                //?????\\Read Mode 1
    NF_CMD(0x80);                               // Write 1st command,数据输入
    NF_ADDR(0);                                 // Column 0
    NF_ADDR((blockPage>>8)&0xff);               // Block & page num.
    for(i=0;i
    NF_WRDATA(*bufPt++);                    // Write one page to NFM from buffer
    seBuf[0]=rNFECC0;
    seBuf[1]=rNFECC1;
    seBuf[2]=rNFECC2;
    seBuf[5]=0xff;                          // Marking good block
    for(i=0;i
    NF_WRDATA(seBuf);                    // Write spare array(ECC and Mark)
[q5]
    NF_CMD(0x10);                           // Write 2nd command
    for(i=0;i                     //tWB = 100ns. ////??????
    NF_WAITRB();                            //wait tPROG 200~500us;
    NF_CMD(0x70);                           // Read status command
    for(i=0;i                      //twhr=60ns
    if (NF_RDDATA()&0x1)                    // Page write error
        NF_nFCE_H();
    Uart_Printf("[PROGRAM_ERROR:block#=%d]\n",block);
    return 0;
    else
        NF_nFCE_H();
    #if (WRITEVERIFY==1)
    //return NF_VerifyPage(block,page,pPage);
    #else
    return 1;
    #endif
继承事业,薪火相传
