/* Module title: f */
/* Module type: des subrutine */
/* Author: YXH */
/* Date: 2012-07-13 */
/* Last changed by: YXH */
/* Functional Description: The chipher function */
/* input parameter 1: pointer to first byte in key string */
/* 2: pointer to a 32 bit input string */
/* 3: pointer to a 32 bit output string */
void f(uint8_t *skey, uint8_t *a_str, uint8_t *x_str)
uint8_t e_str[8], y_str[8], z_str[8];
uint8_t k;
transpose(a_str, e_str, etr, 64);
for (k=0; k < 8; ++k)
y_str[k] = (e_str[k] ^ skey[k]) & 63;
z_str[k] = s[k] [y_str[k]];
transpose(z_str, x_str, ptr, 32);
//源码完毕 |
