STM32-FSMC-NOR FLASH(3)
#include "fsmc_nor.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define Bank1_NOR2_ADDR       ((u32)0x64000000)
/* Delay definition */
#define BlockErase_Timeout    ((u32)0x00A00000)
#define ChipErase_Timeout     ((u32)0x30000000)
#define Program_Timeout       ((u32)0x00001400)
/* Private macro -------------------------------------------------------------*/
#define ADDR_SHIFT(A) (Bank1_NOR2_ADDR + (2 * (A)))
#define NOR_WRITE(Address, Data)  (*(vu16 *)(Address) = (Data)) /* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/ /* Private functions ---------------------------------------------------------*/
/******************************************************************************* * Function Name  : FSMC_NOR_Init
* Description    : Configures the FSMC and GPIOs to interface with the NOR memory.
*                  This function must be called before any write/read operation *                  on the NOR.
* Input          : None
* Output         : None
* Return         : None
*******************************************************************************/ void FSMC_NOR_Init(void)
FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;   FSMC_NORSRAMTimingInitTypeDef  p;
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD |
RCC_APB2Periph_GPIOE |
RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
/*-- GPIO Configuration ------------------------------------------------------*/   /* NOR Data lines configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 |                                 GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOE, &GPIO_InitStructure);
/* NOR Address lines configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |
GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 |
GPIO_Pin_13 |
GPIO_Init(GPIOF, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 |                                 GPIO_Pin_3 | GPIO_Pin_4 |
GPIO_Pin_5;
GPIO_Init(GPIOG, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 |
GPIO_Pin_13;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
/* NOE and NWE configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
/* NE2 configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
/*-- FSMC Configuration ----------------------------------------------------*/   p.FSMC_AddressSetupTime = 0x05;     /*ADDSET  地址建立时间*/   p.FSMC_AddressHoldTime = 0x00;    /*ADDHOLD 地址保持时间*/   p.FSMC_DataSetupTime = 0x07;     /*DATAST 数据建立时间*/
p.FSMC_BusTurnAroundDuration = 0x00;   /*BUSTURN 总线返转时间*/   p.FSMC_CLKDivision = 0x00;      /*CLKDIV 时钟分频*/
p.FSMC_DataLatency = 0x00;     /*DATLAT 数据保持时间*/
p.FSMC_AccessMode = FSMC_AccessMode_B;   /*访问模式*/
FSMC_NORSRAMInitStructure.FSMC_Bank =
FSMC_Bank1_NORSRAM2;    // NOR/SRAM的存储块,共4个选项
博泰典藏网btdcw.com包含总结汇报、高中教育、经管营销、行业论文、计划方案、农林牧渔、外语学习、工程科技、表格模板、高等教育、旅游景点以及STM32-FSMC-NOR FLASH等内容。
继承事业,薪火相传
