Code (inc. data) RO Data RW Data ZI Data Debug Object Name
172 10 0 4 0 995 delay.o//delay.c里面,fac_us和fac_ms,共占用4字节
112 12 0 0 0 427 led.o
72 26 304 0 2048 828 startup_stm32f10x_hd.o //启动文件,里面定义了Stack_Size为0X800,所以这里是2048.
712 52 0 0 0 2715 sys.o
348 154 0 6 0 208720 test.o//test.c里面,stack_dir和cpu_endian 以及*addr ,占用6字节.
384 24 0 8 200 3050 usart.o//usart.c定义了一个串口接收数组buffer,占用200字节.
1800 278 336 20 2248 216735 Object Totals //总共2248+20字节
0 0 32 0 0 0 (incl. Generated)
0 0 0 2 0 0 (incl. Padding)//2字节用于对其 ---------------------------------------------------------------------- Code (inc. data) RO Data RW Data ZI Data Debug Library Member Name 8 0 0 0 0 68 __main.o
104 0 0 0 0 84 __printf.o
52 8 0 0 0 0 __scatter.o
26 0 0 0 0 0 __scatter_copy.o
28 0 0 0 0 0 __scatter_zi.o
48 6 0 0 0 96 _printf_char_common.o
36 4 0 0 0 80 _printf_char_file.o
92 4 40 0 0 88 _printf_hex_int.o
184 0 0 0 0 88 _printf_intcommon.o
0 0 0 0 0 0 _printf_percent.o
4 0 0 0 0 0 _printf_percent_end.o
6 0 0 0 0 0 _printf_x.o
12 0 0 0 0 72 exit.o
8 0 0 0 0 68 ferror.o
6 0 0 0 0 152 heapauxi.o
2 0 0 0 0 0 libinit.o
2 0 0 0 0 0 libinit2.o
2 0 0 0 0 0 libshutdown.o
2 0 0 0 0 0 libshutdown2.o
8 4 0 0 96 68 libspace.o //库文件(printf使用),占用了96字节
24 4 0 0 0 84 noretval__2printf.o
0 0 0 0 0 0 rtentry.o
12 0 0 0 0 0 rtentry2.o
6 0 0 0 0 0 rtentry4.o
2 0 0 0 0 0 rtexit.o
10 0 0 0 0 0 rtexit2.o
74 0 0 0 0 80 sys_stackheap_outer.o
2 0 0 0 0 68 use_no_semi.o
2 0 0 0 0 68 use_no_semi_2.o
450 8 0 0 0 236 faddsub_clz.o
388 76 0 0 0 96 fdiv.o
62 4 0 0 0 84 ffixu.o
38 0 0 0 0 68 fflt_clz.o
258 4 0 0 0 84 fmul.o
140 4 0 0 0 84 fnaninf.o
10 0 0 0 0 68 fretinf.o
0 0 0 0 0 0 usenofp.o ----------------------------------------------------------------------
2118 126 42 0 100 1884 Library Totals //调用的库用了100字节.
10 0 2 0 4 0 (incl. Padding) //用于对其多占用了4个字节 ---------------------------------------------------------------------- Code (inc. data) RO Data RW Data ZI Data Debug Library Name 762 30 40 0 96 1164 c_w.l
1346 96 0 0 0 720 fz_ws.l ----------------------------------------------------------------------
2118 126 42 0 100 1884 Library Totals ---------------------------------------------------------------------- ==============================================================================
3918 404 378 20 2348 217111 Grand Totals
3918 404 378 20 2348 217111 ELF Image Totals
3918 404 378 20 0 0 ROM Totals ============================================================================== Total RO Size (Code + RO Data) 4296 ( 4.20kB)
Total RW Size (RW Data + ZI Data) 2368 ( 2.31kB) //总共占用:2248+20+100=2368.
Total ROM Size (Code + RO Data + RW Data) 4316 ( 4.21kB) ==============================================================================
通过这个文件,我们就可以分析整个内存,是怎么被占用的,具体到每个文件,占用多少.一目了然了.
4,最后,看看整个测试代码:
main.c代码如下,工程见附件.
#include "sys.h"
#include "usart.h"
#include "delay.h"
#include "led.h"
#include "beep.h"
#include "key.h"
//ALIENTEK战舰STM32开发板堆栈增长方向以及CPU大小端测试 //保存栈增长方向
//0,向下增长;1,向上增长.
static u8 stack_dir; //CPU大小端
//0,小端模式;1,大端模式.
static u8 cpu_endian; |
