linux 2.6下编译usb驱动和arm板进行数据通信
文件原型drivers/usb/misc/usblcd.c
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <linux/slab.h>
#include <linux/errno.h>
#include <asm/uaccess.h>
#include <linux/usb.h>
#define DRIVER_VERSION "USBLCD Driver Version 1.05"
#define USBLCD_MINOR        144
#define IOCTL_GET_HARD_VERSION    1
#define IOCTL_GET_DRV_VERSION    2
static struct usb_device_id id_table [] = {
    { .idVendor = 0x10D2, .match_flags = USB_DEVICE_ID_MATCH_VENDOR, },
    { .idVendor = 0x8086, .match_flags = USB_DEVICE_ID_MATCH_VENDOR, },//gliethttp_20080527添加自己的vid
    { .idVendor = 0x1286, .match_flags = USB_DEVICE_ID_MATCH_VENDOR, },//gliethttp_20080527添加自己的vid
MODULE_DEVICE_TABLE (usb, id_table);
struct usb_lcd {
    struct usb_device *    udev;            /* init: probe_lcd */
    struct usb_interface *  interface;        /* the interface for this device */
    unsigned char *         bulk_in_buffer;        /* the buffer to receive data */
    size_t            bulk_in_size;        /* the size of the receive buffer */
    __u8            bulk_in_endpointAddr;    /* the address of the bulk in endpoint */
    __u8            bulk_out_endpointAddr;    /* the address of the bulk out endpoint */
    struct kref        kref;
    struct semaphore    limit_sem;        /* to stop writes at full throttle from
                             * using up all RAM */
#define to_lcd_dev(d) container_of(d, struct usb_lcd, kref)
#define USB_LCD_CONCURRENT_WRITES    1   //gliethttp_20080527同时允许1个task控制写函数,其他task将阻塞
static struct usb_driver lcd_driver;
static DEFINE_MUTEX(usb_lcd_open_mutex);
static void lcd_delete(struct kref *kref)
    struct usb_lcd *dev = to_lcd_dev(kref);
    usb_put_dev(dev->udev);
    kfree (dev->bulk_in_buffer);
    kfree (dev);
static int lcd_open(struct inode *inode, struct file *file)
    struct usb_lcd *dev;
    struct usb_interface *interface;
    int subminor;
    int retval = 0;
    subminor = iminor(inode);
    mutex_lock(&usb_lcd_open_mutex);
    interface = usb_find_interface(&lcd_driver, subminor);
    if (!interface) {
        err ("USBLCD: %s - error, can't find device for minor %d",
             __FUNCTION__, subminor);
        retval = -ENODEV;
        goto exit;
    dev = usb_get_intfdata(interface);
    if (!dev) {
        retval = -ENODEV;
        goto exit;
    /* increment our usage count for the device */
    kref_get(&dev->kref);
    /* save our object in the file's private structure */
    file->private_data = dev;
exit:
    mutex_unlock(&usb_lcd_open_mutex);
    return retval;
继承事业,薪火相传
