linux 2.6下编译usb驱动和arm板进行数据通信(2)
static int lcd_release(struct inode *inode, struct file *file)
struct usb_lcd *dev;
dev = (struct usb_lcd *)file->private_data;
if (dev == NULL)
return -ENODEV;
/* decrement the count on our device */
kref_put(&dev->kref, lcd_delete);
return 0;
static ssize_t lcd_read(struct file *file, char __user * buffer, size_t count, loff_t *ppos)
int retval = 0;
int bytes_read;
/* do a blocking bulk read to get data from the device */
retval = usb_bulk_msg(dev->udev,
usb_rcvbulkpipe(dev->udev, dev->bulk_in_endpointAddr),
dev->bulk_in_buffer,
min(dev->bulk_in_size, count),
&bytes_read, 30*60*1000);//gliethttp_20080527 修改超时时间
/* if the read was successful, copy the data to userspace */
if (!retval) {
if (copy_to_user(buffer, dev->bulk_in_buffer, bytes_read))
retval = -EFAULT;
else
retval = bytes_read;
return retval;
