linux 2.6下编译usb驱动和arm板进行数据通信(3)
static int lcd_ioctl(struct inode *inode, struct file *file, unsigned int cmd, unsigned long arg)
struct usb_lcd *dev;
u16 bcdDevice;
char buf[30];
dev = (struct usb_lcd *)file->private_data;
if (dev == NULL)
return -ENODEV;
switch (cmd) {
case IOCTL_GET_HARD_VERSION:
bcdDevice = le16_to_cpu((dev->udev)->descriptor.bcdDevice);
sprintf(buf,"%1d%1d.%1d%1d",
(bcdDevice & 0xF000)>>12,
(bcdDevice & 0xF00)>>8,
(bcdDevice & 0xF0)>>4,
(bcdDevice & 0xF));
if (copy_to_user((void __user *)arg,buf,strlen(buf))!=0)
return -EFAULT;
break;
case IOCTL_GET_DRV_VERSION:
sprintf(buf,DRIVER_VERSION);
return -EFAULT;
break;
default:
return -ENOTTY;
break;
return 0;
static void lcd_write_bulk_callback(struct urb *urb)
dev = (struct usb_lcd *)urb->context;
/* sync/async unlink faults aren't errors */
if (urb->status &&
!(urb->status == -ENOENT ||
urb->status == -ECONNRESET ||
urb->status == -ESHUTDOWN)) {
dbg("USBLCD: %s - nonzero write bulk status received: %d",
__FUNCTION__, urb->status);
/* free up our allocated buffer */
usb_buffer_free(urb->dev, urb->transfer_buffer_length,
urb->transfer_buffer, urb->transfer_dma);
up(&dev->limit_sem);
