linux 2.6下编译usb驱动和arm板进行数据通信(5)
* usb class driver info in order to get a minor number from the usb core,
* and to have the device registered with the driver core
static struct usb_class_driver lcd_class = {
.name = "gliethttp_flash%d",
.fops = &lcd_fops,
.minor_base = USBLCD_MINOR,
static int lcd_probe(struct usb_interface *interface, const struct usb_device_id *id)
struct usb_lcd *dev = NULL;
struct usb_host_interface *iface_desc;
struct usb_endpoint_descriptor *endpoint;
size_t buffer_size;
int i;
int retval = -ENOMEM;
/* allocate memory for our device state and initialize it */
dev = kzalloc(sizeof(*dev), GFP_KERNEL);
if (dev == NULL) {
err("Out of memory");
goto error;
kref_init(&dev->kref);
sema_init(&dev->limit_sem, USB_LCD_CONCURRENT_WRITES);
dev->udev = usb_get_dev(interface_to_usbdev(interface));
dev->interface = interface;
//gliethttp_20080527
if (le16_to_cpu(dev->udev->descriptor.idProduct) != 0x0001) {
warn(KERN_INFO "USBLCD model not supported.");
return -ENODEV;
/* set up the endpoint information */
/* use only the first bulk-in and bulk-out endpoints */
iface_desc = interface->cur_altsetting;
for (i = 0; i < iface_desc->desc.bNumEndpoints; ++i) {
endpoint = &iface_desc->endpoint[i].desc;
if (!dev->bulk_in_endpointAddr &&
usb_endpoint_is_bulk_in(endpoint)) {
/* we found a bulk in endpoint */
buffer_size = le16_to_cpu(endpoint->wMaxPacketSize);
dev->bulk_in_size = buffer_size;
dev->bulk_in_endpointAddr = endpoint->bEndpointAddress;
dev->bulk_in_buffer = kmalloc(buffer_size, GFP_KERNEL);
if (!dev->bulk_in_buffer) {
err("Could not allocate bulk_in_buffer");
goto error;
if (!dev->bulk_out_endpointAddr &&
usb_endpoint_is_bulk_out(endpoint)) {
/* we found a bulk out endpoint */
dev->bulk_out_endpointAddr = endpoint->bEndpointAddress;
if (!(dev->bulk_in_endpointAddr && dev->bulk_out_endpointAddr)) {
err("Could not find both bulk-in and bulk-out endpoints");
goto error;
/* save our data pointer in this interface device */
usb_set_intfdata(interface, dev);
/* we can register the device now, as it is ready */
retval = usb_register_dev(interface, &lcd_class);
if (retval) {
/* something prevented us from registering this driver */
err("Not able to get a minor for this device.");
usb_set_intfdata(interface, NULL);
goto error;
i = le16_to_cpu(dev->udev->descriptor.bcdDevice);
info("USBLCD Version %1d%1d.%1d%1d found at address %d",
(i & 0xF000)>>12,(i & 0xF00)>>8,(i & 0xF0)>>4,(i & 0xF),
dev->udev->devnum);
/* let the user know what node this device is now attached to */
info("USB LCD device now attached to USBLCD-%d", interface->minor);
return 0;
error:
if (dev)
kref_put(&dev->kref, lcd_delete);
return retval;
