linux 2.6下编译usb驱动和arm板进行数据通信(8)
BOOL OpenUsbPort (long int DelayTime)
char Message[100];
unsigned long int Seconds, count=100;
BOOL DeviceFound = FALSE,MessageEnable = TRUE;
struct termios options, old_options;
int file;
file = open(DeviceName, O_RDWR);
if (file < 0)
printf("ERROR: Open driver failed:%d \n", errno);
return FALSE;
usb_fd = file;
usb_dbg("%s end, usb_fd %d\n", __func__, usb_fd);
return TRUE;
BOOL WriteUsb (WTPCOMMAND WtpCmd,DWORD dwCmdSize)
char Message[100];
int result;
DWORD IOCTL_CMD, dwActualBytes = 0;
BOOL IsOk;
if (usb_fd == 0)
sprintf (Message," Error: OpenUsbPort must be called prior to calling WriteUsb!");
usb_dbg("%s %d USB COMMUNICATIONS ERROR\n", __func__, __LINE__);
return FALSE;
result = write( usb_fd, &WtpCmd, dwCmdSize);
if (result < 0)
sprintf (Message," Error: WriteUsb failed with error %d", result);
if (dbg_level)
sprintf (Message,"IOCTL code: %X",IOCTL_CMD);
usb_dbg("%s %d USB write %d bytes\n", __func__, __LINE__, result);
return TRUE;
BOOL ReadUsb(WTPSTATUS *WtpStatus, DWORD dwSize, PDWORD pBytesRead)
int result;
usb_dbg("%s %d USB read %d bytes\n", __func__, __LINE__, dwSize);
result = read(usb_fd, WtpStatus, dwSize);
if (result <= 0)
#if ___output_log__
printf("%s return %d\n", __func__, result);
#endif
return FALSE;
dbg_usbStatus(WtpStatus);
*pBytesRead = result;
return TRUE;
BOOL ReadUsbCharBuffer (char *WtpMessage,DWORD dwSize,PDWORD pBytesRead)
int result;
if (usb_fd < 0)
printf (" Error: OpenUsbPort must be called prior to calling ReadUsb!");
return FALSE;
result = read(usb_fd, WtpMessage, dwSize);
if (result < 0 )
printf (" Error: ReadFile failed with error\n");
return FALSE;
if (*pBytesRead != dwSize) return FALSE;
return TRUE;
void CloseUsbPort ()
if (usb_fd != 0) close (usb_fd);
