在ISE中调用modelsim时不认 'xilinxcorelib'
在XILINX ISE的安装目录下\BIN\NT\有COMPLXLIB.EXE,可以编译XILINX的库。但前提是XILINX要新版本,好像是5.1之后吧。具体格式: compxlib -s mti_se -f all -l vhdl -o e:\Modeltech_5.8a 其中最后的是MODELSIM的安装目录。做完之后需要手动修改MODELSIM.INI文件让MODELSIM启动时可以找到配置,如下: [Library] std = $MODEL_TECH/../std ieee = $MODEL_TECH/../ieee verilog = $MODEL_TECH/../verilog std_developerskit = $MODEL_TECH/../std_developerskit synopsys = $MODEL_TECH/../synopsys modelsim_lib = $MODEL_TECH/../modelsim_lib logiblox = $MODEL_TECH/../logiblox uni9000 = $MODEL_TECH/../uni9000 simprim = $MODEL_TECH/../simprim simprims_ver = $MODEL_TECH/../simprims_ver unisim = $MODEL_TECH/../unisim unisims_ver = $MODEL_TECH/../unisims_ver xilinxcorelib = $MODEL_TECH/../xilinxcorelib xilinxcorelib_ver = $MODEL_TECH/../xilinxcorelib_ver |
