- 来自
- 燕山大学
1. tar xvfz qt-2.3.10.tar.gz
2.
QTDIR=/home/qt-2.3.10
LD_LIBRARY_PATH=$QTDIR/lib LD_LIBRARY_PATH
PATH=$QTDIR/bin PATH
export QTDIR LDLIBRARY_PATH
3. ./configure -xplatform. linux-arm-g++ -shared
注意配置时 -shared前有个空格的,否则配置出错。
输入yes,5,16,no
4. make
5. 后来更换高版本的编译器后 连接例子时提示未定义的 __cxa_pure_virtual函数,解决方法是
改变该例子的Makefile里的arm-linux-gcc为 arm-linux-g++即可。
出错误后:
vim src/allmoc.cpp 加入下面的函数。
extern "C" void
__cxa_pure_virtual(void)
//CYG_FAIL("attempt to use a virtual function before object has been constructed");
for(;;);
void* operator new[](size_t size)
return malloc(size);
void* operator new(size_t size)
void operator delete[](void* p)
free(p);
void operator delete[](void* p, size_t size)
free(p);
void operator delete(void* p)
free(p);
void operator delete(void* p, size_t size)
free(p);
拷贝lib目录到根文件系统就可以测试了。
arm-linux-gcc -v
Reading specs from /home/toolchain/arm/3.4.1/bin/../lib/gcc/arm-linux/3.4.1/specs
Configured with: /work/crosstool-0.27/build/arm-linux/gcc-3.4.1-glibc-2.3.2/gcc-3.4.1/configure --target=arm-linux --host=i686-host_pc-linux-gnu --prefix=/usr/local/arm/3.4.1 --with-headers=/usr/local/arm/3.4.1/arm-linux/include --with-local-prefix=/usr/local/arm/3.4.1/arm-linux --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-__cxa_atexit --enable-languages=c,c++ --enable-shared --enable-c99 --enable-long-long
Thread model: posix
gcc version 3.4.1 |
