3-8译码器的几种Verilog HDL代码描述方法(2)
第四种:for语句(1
`timescale 10ns/1ns
module decode3_8(data_out,data_in,enable) ;
input [2:0] data_in;
input enable;
output [7:0] data_out;
reg [7:0] data_out;
integer i;
always @(data_in orenable)
begin
if(enable)
begin
            for(i=0;i<8;i=i+1)
begin
               if(data_in==i)
data_out=0;
                  else
data_out=1;
end
end
else
data_out=8'hff;
end
endmodule
第五种:带条件的连续赋值
`timescale 10ns/1ns
input enable;
assign data_out =
({enable,data_in}==4'b1000)?8'b1111_1110:
({enable,data_in}==4'b1001)?8'b1111_1101:
({enable,data_in}==4'b1010)?8'b1111_1011:
({enable,data_in}==4'b1011)?8'b1111_0111:
({enable,data_in}==4'b1100)?8'b1110_1111:
({enable,data_in}==4'b1101)?8'b1101_1111:
({enable,data_in}==4'b1110)?8'b1011_1111:
({enable,data_in}==4'b1111)?8'b0111_1111:
8'b1111_1111;
endmodule
第六种:for语句(2
`timescale 10ns/1ns
input enable;
reg [7:0] data_out;
integer i;
begin
data_out=8'hff;
if(enable)
begin
for(i=0;i<8;i=i+1)
begin
if(data_in==i)
data_out =255-(1<<i);
             end
      end
else
data_out=8'hff;
end
endmodule
Testbench写法:
以使用CadenceNcverilogSimvision工具为例来说明:
`timescale 10ns/1ns
module decode3_8_tb;
reg  [2:0] data_in_tb;
wire  [7:0] data_out_tb;
reg   enable_tb;
decode3_8 decode3_8(.data_in(data_in_tb),.data_out (data_out_tb ),.enable(enable_tb));
initial
begin
    $shm_open(“tb.shm”);
   $shm_probe(“AC”);
enable_tb=0;
data_in_tb=0;
#20 enable_tb=1;
#50 data_in_tb =0;
#50 data_in_tb=1;
#50 data_in_tb=2;
#50 data_in_tb=3;
#50 data_in_tb=4;
#50 data_in_tb=5;
#50 data_in_tb=6;
#50 data_in_tb=7;
$finish();
end
endmodule
继承事业,薪火相传
