Verilog代码标准(6)
Verilog代码标准(6)
2.流程
1. 完成第一个字模块时,请提交该模块代码,进行规范检查评审。
2. Coding 期间 每两星期 提交依次代码和review报告。
         Review报告主要包括内容:
             ·  Review工作时,review的代码模块
             ·  参与人
             ·  发现的缺陷和解决情况。
         Review建议:
(1)  制定review计划;(2) 每次review代码不超过500行。
ANNEX
   CODESTYLE TEMPLATE
    This a template of verilog code file, including file header and themain body of code in which some coding rules are demonstrated.
//  Copyright(c)2005, Hisilicon Technologies Co., Ltd
//  All rights reserved
//   IPLIB INDEX    :   IP lib index just as UTOPIA_B
//   IPName         :   the top module_name of this ip, usually, issame as
                        the small ipclassified name just as UTOPIA
//  File name        :   file_name of this file just as tx_fifo.v
//  Module name     :   module_name of this file just as TX_FIFO
//  Full name        :   complete English name of the abbreviatedmodule_name
//  Author          :   Author
//  Email           :   Author’s email
//  Data            :   2005/07/20
//  Version          :   current version, just this: v1.0, must sameas the CVS version
//  Abstract         :
//  Called by         :   Father module just as TX_PROC
//  Modification history
// Version       Data(yyyy/mm/dd)   name
// Description
// $Log$
//DEFINE(s)
//`define UDLY 1    //Unit delay, for non-blocking assignmentsin sequential logic
//DEFINE MODULE PORT
module MODULE_NAME(
                   //INPUT
                    rest_n         ,
                    clk_*          ,
                    a_din          ,
                    b_din          ,
                   //OUTPUT
                    a_dout         ,
                   b_dout
//DEFINE PARAMETER
//Parameter(s)
//DEFINE INPUT
input             rst_n        ;   //reset, active low .
input            clk_*        ;   //clock signal, 50M .
input [n:0]       a_din        ;   //*****
input [k:0]       b_din        ;   //*****
//DEFINE OUTPUT
output [m:0]    a_dout      ;   //*****
output [i:0]     b_dout     ;    //*****
//OUTPUT ATTRIBUTE
//REGS
reg  [m:0]     a_dout     ;   //*****
//WIRES
wire [i:0]      b_dout     ;   //*****
//INNER SIGNAL DECLARATION
//REGS
reg  [3:0]       counter     ;   //*****
//WIRES
wire [7:0]       temp1      ;   //*****
//INSTANTCE MODULE
//instance of module MODULE_NAME_Afilename:module_name_a.v
MODULE_NAME_A U_MUDULE_NAME_A(
                  .A               (A              ),
                  .B               (B              ),
                  .C               (C              )
继承事业,薪火相传
