利用FPGA实现PCI总线接口及Windows驱动实现
关于PCI总线协议,资料网上、书本都是。这里我们仅仅对重点对利用FPGA实现PCI总线接口问题进行简单分析。下图是PCI总线接口信号:
配置空间寄存器操作时序如下图:
配置寄存器空间写时序如下图:
依照状态机的编程思路。
部分Verilog代码如下:
      ST_CFGREAD: begin
           enable <= EN_RD;
           if (~irdy || trdy) begin
                case (address)
                    0: data <= { DEVICE_ID,VENDOR_ID };
                    1: data <= { 5'b0,DEVSEL_TIMING, 9'b0,  14'b0, memen,1'b0};
                    2: data <= {DEVICE_CLASS, DEVICE_REV };
                    4: data <= { 12'b0,baseaddr, 8'b0, 4'b0010 }; // baseaddr + request mem < 1Mbyte
                    11: data <={SUBSYSTEM_ID, SUBSYSTEM_VENDOR_ID };
                    16: data <= { 24'b0,baseaddr };
                    default: data <='h00000000;
               endcase
                address <= address + 1'b1;
           end
           if (frame && ~irdy && ~trdy) begin
                devsel <= 1;
                state <= ST_IDLE;
                enable <= EN_TR;
           end
       end
       ST_CFGWRITE: begin
           enable <= EN_WR;
           if (~irdy) begin
                case (address)
                    4: baseaddr <=ad[19:12];  // XXX examine cbe
                    1: memen <= ad[1];
                    default: ;
                endcase
                if (frame) begin
                    devsel <= 1;
                    state <= ST_IDLE;
                    enable <= EN_TR;
                end
           end
       end
继承事业,薪火相传
