Cyclone II电源设计初步(3)
Cyclone II电源设计初步(3)
        MultiVolt I/O Interface(P2-60)
        The Cyclone II architecture supports the MultiVolt I/O interface feature,
        which allows Cyclone II devices in all packages to interface with systems
        of different supply voltages. Cyclone II devices have one set of V
        CC
         pins
        ( VCCINT) that power the internal device  logic array and input buffers that
        use the LVPECL, LVDS, HSTL, or SSTL I/O standards. Cyclone II devices
        also have four or eight sets of VCC pins (VCCIO ) that power the I/O
        output drivers and input buffers that use the LVTTL, LVCMOS, or PCI
        I/O standards.
        The Cyclone II  VCCINT pins must always be co nnected to a 1.2-V power
        supply. If the V
        CCINT
         level is 1.2 V, then input pi ns are 1.5-V, 1.8-V, 2.5-V,
        and 3.3-V tolerant. The VCCIO  pins can be connected to either a 1.5-V,
        1.8-V, 2.5-V, or 3.3-V power supply, depending on the output
        requirements. The output levels are co mpatible with systems of the same
        voltage as the power supply (i.e., when VCCIO pins are connected to a
        1.5-V power supply, the output levels are compatible with 1.5-V systems).
        When VCCIO  pins are connected to a 3.3-V power supply, the output high
        is 3.3-V and is compatible with 3.3-V systems.
        Each I/O bank has its own VCCIO pins. A single de vice can support
        1.5-V, 1.8-V, 2.5-V, and 3.3-V interfac es; each individual bank can support
        a different standard with different I/O voltages. Each bank also has
        dual-purpose VREF pins to support any one of the voltage-referenced
        standards (e.g., SSTL-2) independently. If an I/O bank does not use
        voltage-referenced standards, the  VREF pins are available as user I/O
        pins.
        Each I/O bank can support multiple standards with the same VCCIO for
        input and output pins. For example, when V
        CCIOis 3.3-V, a bank can support LVTTL, LVCMOS, and 3.3-V  PCI for inputs and outputs.
        Voltage-referenced standards can be supported in an I/O bank using any
        number of single-ended or differential  standards as long as they use the
        same VREF and a compatible VCCIO value.
        of different supply voltages. Cyclone II devices have one set of VCC pins
        I/O standards.
        The Cyclone II  VCCINT pins must always be co nnected to a 1.2-V power supply. If the V
        CCINT level is 1.2 V, then input pi ns are 1.5-V, 1.8-V, 2.5-V,
继承事业,薪火相传
