lwIP协议栈的pbuf结构体
lwIP协议栈的pbuf结构体
pbuf结构体位于src/include/lwip/pbuf.h中
以太网中断收到的数据就先存放到这个结构体组成的数据链中,然后将它交付给上层协议.
这个结构体可以说是无处不在.
[cpp] view plaincopyprint?
  • struct pbuf {
  •   /** next pbuf in singly linked pbuf chain 指向下一个pbuf*/
  •   struct pbuf *next;
  •   /** pointer to the actual data in the buffer 指向有效数据区*/
  •   void *payload;
  •    * total length of this buffer and all next buffers in chain
  •    * belonging to the same packet.
  •    * 数据链的总长度
  •    * For non-queue packet chains this is the invariant:
  •    * p->tot_len == p->len + (p->next? p->next->tot_len: 0)
  •   u16_t tot_len;
  •   /** length of this buffer 这个缓冲区的长度*/
  •   u16_t len;
  •   /** pbuf_type as u8_t instead of enum to save space
  •       pbuf的类型,有PBUF_RAM、PBUF_ROM、PBUF_REF和PBUF_POOL,这些类型指明指针payload指向的数据的类型*/
  •   u8_t /*pbuf_type*/ type;
  •   /** misc flags 混合标志位,每一位代表一个标志*/
  •   u8_t flags;
  •    * the reference count always equals the number of pointers
  •    * that refer to this pbuf. This can be pointers from an application,
  •    * the stack itself, or pbuf->next pointers from a chain.
  •      统计有多少个指针指向这个pbuf.这些指针可能是应用程序的指针,
  •      协议栈自己的指针或者数据链中的pbuf->next指针,ref为0时,才可以释放该pbuf
  •   u16_t ref;
  • #if LWIP_PTPD          //如果使能了网络测量和控制系统的精密时钟同步协议标准
  •   /* the time at which the packet was received, seconds component */
  •   u32_t time_s;
  •   /* the time at which the packet was received, nanoseconds component */
  •   u32_t time_ns;
  • #endif /* #if LWIP_PTPD */
继承事业,薪火相传
