aaronhou@sohu.c 该用户已被删除
我有两台dsp教学系统,一台是北理工达盛的TMS320vc5402,一台是台弯产北京掌宇的TMS320c5402,由于是初学,问题一箩筐,首先是北理工的问题--一个很简单的数据存储试验,可rebuild时出现
ERROR ".rcp":There is no Visual Linker Recipe in the project
ERROR ".rcp"ouble click the message to create a Visual Linker Recipe.
燃后我照做打开了dsp/bios配制窗口,工程中出现.rcp文件,取代了原来的cmd文件,请问
这是为何?都需要这么做吗,.cmd不才是链接文件吗?
之后我再rebuild,没有错误,然后load program调出.out文件,但又出现错误--file:c\ti\…….out:load failed.A section of your program falls into a memory region that is not writable.Check your linker configuration and /or memory map.
请问该如何解决呢?另外该实验箱与pc连接的仿真盒上面只有power灯亮,而target一直不亮,是不是连接有问题,target灯是指示什么的?
而北京掌宇的开发环境不是ccs,是c54 code explorer,可刚进去后让选择lpt1或lpt4,lpt1的地址是0x378,lpt4的地址是0x217,由于是并口连接,我认为是选择LPT1,可不论我选择那一个,都出现同一关于DSP Device Driver的提示---can't Initialize Target DSP;can't Access HPI port on the DSK;please ensure the cabling is connected properly,you have selected the correct parallel port,and the DSK is powered on.可我真看不出那里接错了,请指教,多谢!! |
