麻烦各位大侠帮改一下错!!
麻烦各位大侠帮改一下错!!
下面是卷积码编码VHDL程序,编译时有点问题,麻烦大家帮看一下,不胜感激。
LIBRARY IEEE;
USE IEEE.STD_ LOGIC_1164.ALL;
ENTITY bianma IS
  PORT ( datain: IN STD_LOGIC;
           clk, clr: IN STD_LOGIC;
          dataout: OUT STD_LOGIC);
END bianma;
ARCHITECTURE behave OF bianma IS
 COMPONENT cff2;
  PORT ( d, clk, clr: IN STD_LOGIC;
   q: BUFFER STD_LOGIC);
 END COMPONENT;
 COMPONEN T xort4;
  PORT (a, b, c, d: IN STD_LOGIC;
   q: OUT STD_LOGIC);
 END COMPONENT;
COMPONENT shift6;
  PORT ( a: IN STD_LOGIC;
   b1, b2, b3, b4: OUT STD_LOGIC);
 END COMPONENT;
 COMPONENT switch21;
  PORT (a, b: IN STD_LOGIC;
   s: IN STD_LOGIC;
   y: OUT STD_LOGIC);
 END COMPONENT;
SIGNAL d1, d2, d3, d4, t: STD_LOGIC;
BEGIN
cffx1: shift6 PORT MAP (a, clk, clr, d1, d2, d3, d4);
cffx2: xort4 PORT MAP (d1, d2, d3, d4, t);
cffx3: switch21 PORT MAP (a, t, clk, q);
END behave;
总是提示:Error (10500): VHDL syntax error at bianma.vhd(16) near text □
[此贴子已经被作者于2007-4-25 8:40:17编辑过]
