在cyclone II starter Board上编译uc/FS文件系统出现问题?
我用Nios IDE 6.0编译uc/FS,把所有的文件系统源代码都放在当前工程目录下,但是有如下错误: **** Incremental build of configuration Debug for project software ****
make -s all Compiling api_dir.c... In file included from ../fs_int.h:27, from ../fs_dev.h:24, from ../api_dir.c:33: ../fs_fsl.h:36: error: parse error before "FS_FILE" ../fs_fsl.h:36: warning: no semicolon at end of struct or union ../fs_fsl.h:37: error: parse error before '*' token ../fs_fsl.h:38: error: parse error before "FS_FILE" ../fs_fsl.h:39: error: parse error before "FS_FILE" ../fs_fsl.h:40: error: parse error before '*' token ../fs_fsl.h:41: error: parse error before '*' token ../fs_fsl.h:44: error: parse error before '*' token ../fs_fsl.h:44: error: parse error before "FS_DIR" ../fs_fsl.h:44: warning: type defaults to `int' in declaration of `fsl_opendir' ../fs_fsl.h:44: warning: data definition has no type or storage class ../fs_fsl.h:45: error: parse error before '*' token ../fs_fsl.h:46: error: parse error before '*' token ../fs_fsl.h:47: error: parse error before '*' token ../fs_fsl.h:51: error: parse error before '}' token ../fs_fsl.h:51: warning: type defaults to `int' in declaration of `FS__fsl_type' ../fs_fsl.h:51: warning: data definition has no type or storage class In file included from ../fs_dev.h:24, from ../api_dir.c:33: ../fs_int.h:59: warning: type defaults to `int' in declaration of `FS__fsl_type' ../fs_int.h:59: warning: no semicolon at end of struct or union ../fs_int.h:59: error: parse error before '*' token ../fs_int.h:60: error: parse error before '*' token ../fs_int.h:60: warning: type defaults to `int' in declaration of `devdriver' ../fs_int.h:60: warning: data definition has no type or storage class ../fs_int.h:65: error: parse error before '}' token ../fs_int.h:65: warning: type defaults to `int' in declaration of `FS__devinfo_type' ../fs_int.h:65: warning: data definition has no type or storage class ../fs_int.h:76: error: parse error before '*' token ../fs_int.h:76: warning: type defaults to `int' in declaration of `FS__pDevInfo' ../fs_int.h:76: warning: data definition has no type or storage class In file included from ../api_dir.c:33: ../fs_dev.h:64: error: parse error before "FS__ramdevice_driver" ../fs_dev.h:64: warning: type defaults to `int' in declaration of `FS__ramdevice_driver' ../fs_dev.h:64: warning: data definition has no type or storage class ../fs_dev.h:65: error: parse error before "FS__windrive_driver" ../fs_dev.h:65: warning: type defaults to `int' in declaration of `FS__windrive_driver' ../fs_dev.h:65: warning: data definition has no type or storage class ../fs_dev.h:66: error: parse error before "FS__smcdevice_driver" ../fs_dev.h:66: warning: type defaults to `int' in declaration of `FS__smcdevice_driver' ../fs_dev.h:66: warning: data definition has no type or storage class ../fs_dev.h:67: error: parse error before "FS__mmcdevice_driver" ../fs_dev.h:67: warning: type defaults to `int' in declaration of `FS__mmcdevice_driver' ../fs_dev.h:67: warning: data definition has no type or storage class ../fs_dev.h:68: error: parse error before "FS__idedevice_driver" ../fs_dev.h:68: warning: type defaults to `int' in declaration of `FS__idedevice_driver' ../fs_dev.h:68: warning: data definition has no type or storage class ../fs_dev.h:69: error: parse error before "FS__flashdevice_driver" ../fs_dev.h:69: warning: type defaults to `int' in declaration of `FS__flashdevice_driver' ../fs_dev.h:69: warning: data definition has no type or storage class ../fs_dev.h:70: error: parse error before "FS__SFlash_Driver" ../fs_dev.h:70: warning: type defaults to `int' in declaration of `FS__SFlash_Driver' ../fs_dev.h:70: warning: data definition has no type or storage class ../fs_dev.h:71: error: parse error before "FS__genericdevice_driver" ../fs_dev.h:71: warning: type defaults to `int' in declaration of `FS__genericdevice_driver' ../fs_dev.h:71: warning: data definition has no type or storage class ../fs_dev.h:72: error: parse error before "FS__NAND2K_Driver" ../fs_dev.h:72: warning: type defaults to `int' in declaration of `FS__NAND2K_Driver' ../fs_dev.h:72: warning: data definition has no type or storage class In file included from ../api_dir.c:34: ../fs_api.h:125:1: warning: "FS_DIRNAME_MAX" redefined In file included from ../fs_dev.h:23, from ../api_dir.c:33: ../FS_ConfDefaults.h:313:1: warning: this is the location of the previous definition In file included from ../api_dir.c:35: ../fs_os.h:33: warning: type defaults to `int' in declaration of `FS__device_type' ../fs_os.h:33: error: parse error before '*' token ../fs_os.h:34: warning: type defaults to `int' in declaration of `FS__device_type' ../fs_os.h:34: error: parse error before '*' token ../api_dir.c: In function `FS_OpenDir': ../api_dir.c:87: error: request for member `fs_ptr' in something not a structure or union ../api_dir.c:103: error: request for member `fs_ptr' in something not a structure or union ../api_dir.c: In function `FS_CloseDir': ../api_dir.c:142: error: request for member `fs_ptr' in something not a structure or union ../api_dir.c:144: error: request for member `fs_ptr' in something not a structure or union ../api_dir.c: In function `FS_ReadDir': ../api_dir.c:177: error: request for member `fs_ptr' in something not a structure or union ../api_dir.c:179: error: request for member `fs_ptr' in something not a structure or union ../api_dir.c: In function `FS_MkDir': ../api_dir.c:235: error: request for member `fs_ptr' in something not a structure or union ../api_dir.c:238: error: request for member `fs_ptr' in something not a structure or union ../api_dir.c: In function `FS_RmDir': ../api_dir.c:298: error: request for member `fs_ptr' in something not a structure or union ../api_dir.c:301: error: request for member `fs_ptr' in something not a structure or union make: *** [obj/api_dir.o] Error 1 Build completed
