1) 根据2410寄存器定义如下的命令宏
#define NF_CMD(cmd) {rNFCMD=cmd;}
#define NF_ADDR(addr) {rNFADDR=addr;}
#define NF_nFCE_L() {rNFCONF&=~(1
#define NF_nFCE_H() {rNFCONF|=(1
#define NF_RSTECC() {rNFCONF|=(1
#define NF_RDDATA() (rNFDATA)
#define NF_WRDATA(data) {rNFDATA=data;}
#define NF_WAITRB() {while(!(rNFSTAT&(1
//wait tWB and check F_RNB pin.
2) NAND 设备的初始化
static void NF_Init(void) //Flash 初始化
rNFCONF=(1 //设置NAND设备的相关寄存器
// 1 1 1 1, 1 xxx, r xxx, r xxx
// En 512B 4step ECCR nFCE="H" tACLS tWRPH0 tWRPH1
NF_Reset();
static void NF_Reset(void) //Flash重置
int i;
NF_nFCE_L();
NF_CMD(0xFF); //reset command
for(i=0;i //tWB = 100ns
NF_WAITRB(); //wait 200~500us;
NF_nFCE_H();
3) NAND设备的识别 //#define ID_K9F1208U0M 0xec76
static U16 NF_CheckId(void) //Id 辨别
int i;
U16 id;
NF_nFCE_L();
NF_CMD(0x90);
NF_ADDR(0x0);
for(i=0;i //wait tWB(100ns)
id=NF_RDDATA() // Maker code(K9F1208U:0xec)
id|=NF_RDDATA(); // Devide code(K9F1208U:0x76)
NF_nFCE_H();
return id;
4) NAND 的擦操作
static int NF_EraseBlock(U32 block)
U32 blockPage=(block
int i;
NF_nFCE_L();
NF_CMD(0x60
[q1]
); // Erase one block 1st command
NF_ADDR(blockPage&0xff); // Page number="0"
NF_ADDR((blockPage>>8)&0xff);
NF_ADDR((blockPage>>16)&0xff);
NF_CMD(0xd0
[q2]
); // Erase one blcok 2nd command
for(i=0;i //wait tWB(100ns)//??????
NF_WAITRB(); // Wait tBERS max 3ms.
NF_CMD(0x70); // Read status command
if (NF_RDDATA()&0x1) // Erase error
NF_nFCE_H();
Uart_Printf("[ERASE_ERROR:block#=%d]\n",block);
return 0;
else
NF_nFCE_H();
return 1;
5) NAND 的读操作
static int NF_ReadPage(U32 block,U32 page,U8 *buffer) //读Flash
int i;
unsigned int blockPage;
U8 ecc0,ecc1,ecc2;
U8 *bufPt=buffer;
U8 se[16];
page=page&0x1f; //32页
blockPage=(block //1Bolck包含32页
NF_RSTECC(); // Initialize ECC
NF_nFCE_L();
NF_CMD(0x00); // Read command
NF_ADDR(0); // Column = 0
NF_ADDR((blockPage>>8)&0xff); // Block & Page num.
NF_ADDR((blockPage>>16)&0xff); //
NF_WAITRB(); // Wait tR(max 12us)
for(i=0;i
*bufPt++=NF_RDDATA(); // Read one page
/************************ECC校验***************************/
ecc0=rNFECC0; //利用2410自带的硬件ECC校验
ecc1=rNFECC1;
ecc2=rNFECC2;
[q3]
for(i=0;i
se=NF_RDDATA(); // Read spare array
//读页内冗余的16B
NF_nFCE_H();
if(ecc0==se[0] && ecc1==se[1] && ecc2==se[2]) //未知使用哪一种软件规范?
{ //比较数据结果是否正确
Uart_Printf("[ECC OK:%x,%x,%x]\n",se[0],se[1],se[2]);
return 1;
else
Uart_Printf("[ECC ERROR(RD):read:%x,%x,%x, reg:%x,%x,%x]\n",
se[0],se[1],se[2],ecc0,ecc1,ecc2);
return 0;
6) NAND 的写操作
static int NF_WritePage(U32 block,U32 page,U8 *buffer) //写Flash
int i;
U8 *bufPt=buffer;
NF_nFCE_L();
NF_CMD(0x0
[q4]
); //?????\\Read Mode 1
NF_CMD(0x80); // Write 1st command,数据输入
NF_ADDR(0); // Column 0
NF_ADDR((blockPage>>8)&0xff); // Block & page num.
for(i=0;i
NF_WRDATA(*bufPt++); // Write one page to NFM from buffer
seBuf[0]=rNFECC0;
seBuf[1]=rNFECC1;
seBuf[2]=rNFECC2;
seBuf[5]=0xff; // Marking good block
for(i=0;i
NF_WRDATA(seBuf); // Write spare array(ECC and Mark)
[q5]
NF_CMD(0x10); // Write 2nd command
for(i=0;i //tWB = 100ns. ////??????
NF_WAITRB(); //wait tPROG 200~500us;
for(i=0;i //twhr=60ns
if (NF_RDDATA()&0x1) // Page write error
NF_nFCE_H();
Uart_Printf("[PROGRAM_ERROR:block#=%d]\n",block);
return 0;
else
NF_nFCE_H();
#if (WRITEVERIFY==1)
//return NF_VerifyPage(block,page,pPage);
#else
return 1;
#endif
