嵌入式系统中的FLASH(6)
嵌入式系统中的FLASH(6)
static int NF_MarkBadBlock(U32 block)                       //标记坏块
    int i;
    U32 blockPage=(block
    seBuf[0]=0xff;
    seBuf[1]=0xff;
    seBuf[2]=0xff;
   seBuf[5]=0x44;                              // Bad blcok mark="0"
[q7]
   NF_nFCE_L();
    NF_CMD(0x50);                               //????
    NF_CMD(0x80);                               // Write 1st command
    NF_ADDR(0x0);                               // The mark of bad block is
    NF_ADDR(blockPage&0xff);                    // marked 5th spare array
    NF_ADDR((blockPage>>8)&0xff);               // in the 1st page.
    NF_ADDR((blockPage>>16)&0xff);
    for(i=0;i
    NF_WRDATA(seBuf);                        // Write spare array
    NF_CMD(0x10);                               // Write 2nd command
    for(i=0;i                         //tWB = 100ns. ///???????
    NF_WAITRB();                                // Wait tPROG(200~500us)
    NF_CMD(0x70);
    for(i=0;i                          //twhr=60ns////??????
    if (NF_RDDATA()&0x1)                        // Spare arrray write error
        NF_nFCE_H();
        Uart_Printf("[Program error is occurred but ignored]\n");
    else
        NF_nFCE_H();
    Uart_Printf("[block #%d is marked as a bad block]\n",block);
    return 1;
int search_logic_block(void)                    //建立物理地址到逻
//辑地址的映射表
    unsigned int block,i,blockPage,logic_no,zone,zone_i;
    U8 SE[16];
    for(i=0;i                         //初始化全局变量
        lg2ph=space_block=0xffff;
    logic_number=0;
    space_nr=0;
    NF_nFCE_L();
    zone=BLOCK_NR/1024;                             //确定NAND设备中zone
//的个数
    for(zone_i=0;zone_i
        //搜索每个zone 内逻辑地址和物理地址的映射关系
        for(block=0;block
            blockPage=((block+zone_i*1024)
        NF_WATIRB();                                //等待R/B#信号有效
        NF_CMD(0x50);                               // 读取每个block内部第
//0个Page内冗余的16个字节
        NF_ADDR(0);                                 // Column 0
        NF_ADDR((blockPage>>8)&0xff);               // Block & page num.
        for(i=0;i se=NF_RDDATA();       // Write spare array
        NF_WATIRB();
        if(se[5]!=0xff)
[q8]
                              //检测是否存在坏块
            printk("\n\rphysic block %d is bad block\n\r",block);
        else if(se[7]!=se[12]
[q9]
            printk("block address1:%d!=block address2 %d\n\r",se[7],se[12]);
        else if((se[6]
[q10]
&0xf8)==0x10)
            //计算该block对应的逻辑地址
            logic_no=((0x7&se[6])>1)+zone_i*1000;
            if(lg2ph[logic_no]!=0xffff)             //说明有2个block拥有相
//同的逻辑地址
                printk("physical block %d and block %d have the same logic number %d\n",lg2ph[logic_no],block,logic_no);
            else lg2ph[logic_no]=block;             //将该block的逻辑地址
//关系记入lg2ph表
            logic_number++;
        else if(se[7]==0xff)                        //说明该block尚未编号
        {space_block[space_nr]=block;
        space_nr++;
    printk("there are totally %d logic blocks\n\r",logic_number);
    NF_nFCE_H();
    return logic_number;
这段代码的主要作用就是产生数组lg2ph[],这个数组的含义就是“块物理地址=lg2ph[逻辑地址]”。
继承事业,薪火相传
