ALT_IRQ_NOT_CONNECTED' undeclared (first use in this function)
我在做中断程序。 在注册函数alt_irq_register中 出现:ALT_IRQ_NOT_CONNECTED' undeclared (first use in this function) 这个错误。 但是我程序中并没有用倒这个啊。。看不倒。。为什么啊? 代码: 很简单的中断。 #include<stdio.h> #include"alt_types.h" #include"system.h" #include"sys/alt_irq.h" #include"altera_avalon_pio_regs.h" volatile int edge_capture; static void handle_button_interrupts(void*context,alt_u32 id) { volatile int*edge_capture_ptr=(volatile int *)context; *edge_capture_ptr=IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE,0);//清边沿捕获寄存器 } static void init_button_pio() { void*edge_capture_ptr=(void*)&edge_capture; IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_PIO_BASE,0Xf); IOWR_ALTERA_ALALON_PIO_EDGE_CAP(BUTTON_PIO_BASE,0x0); alt_irq_register(BUTTON_PIO_IRQ,edge_capture_ptr,handle_button_interrupts); } static void TestButtons(void) { alt_u8 buttons_tested; alt_u8 all_tested; int last_tested; buttons_tested=0x0; all_tested=0xf; edge_capture=0; last_tested=0xffff; prinitf("\nThe test will be end when all buttons have been pressed.\n"); while(buttons_tested!=all_tested) { if(last_tested==edge_capture) {continue;} else { last_tested=edge_capture; switch(edge_capture) { case 0x1: printf("\nBUTTON 1 Press.\n"); buttons_tested=buttons_tested|0x1; break; case 0x2: printf("\nBUTTON 2 Press.\n"); buttons_tested=buttons_tested|0x2; break; case 0x4: printf("\nBUTTON 3 Press.\n"); buttons_tested=buttons_tested|0x4; break; case 0x8: printf("\nBUTTON 4 Press.\n"); buttons_tested=buttons_tested|0x8; break; } } } IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_PIO_BASE,0x0); printf("\nall button press.\n"); usleep(2000000); return ; } static void MenuBegin(alt_8*title) { printf("\n \n"); printf("------------------------------\n"); printf("NIos ii board diagnostics\n"); printf("------------------------------\n"); printf("%s",title); } int main() { MenuBegin("Main Menu:"); TestButtons(); return 0; }
