STM32的时钟系统RCC详细整理(12)
/*----------------  FSMC Configuration ---------------------------------------*/
/*----------------  Enable FSMC Bank1_SRAM Bank ------------------------------*/
  FSMC_Bank1->BTCR[4] = 0x00001011;
  FSMC_Bank1->BTCR[5] = 0x00000200;
#endif /* DATA_IN_ExtSRAM */
#ifdef SYSCLK_FREQ_HSE
  * @brief  Selects HSE as System clock source and configure HCLK, PCLK2
  *          and PCLK1 prescalers.
  * @note   This function should be used only after reset.
  * @param  None
  * @retval None
static void SetSysClockToHSE(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
#if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL && !defined STM32F10X_HD_VL
    /* Enable Prefetch Buffer */
    FLASH->ACR |= FLASH_ACR_PRFTBE;
    /* Flash 0 wait state */
    FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
#ifndef STM32F10X_CL
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
#else
    if (HSE_VALUE <= 24000000)
else
      FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
#endif /* STM32F10X_CL */
#endif
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    /* PCLK1 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
    /* Select HSE as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_HSE;
    /* Wait till HSE is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x04)
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
#elif defined SYSCLK_FREQ_24MHz
static void SetSysClockTo72(void)//系统时钟设置为72M:SYSCLK=72M,HCLK=72M,PCLK1=36M(最高36M),PCLK2=72M,ADCCLK=36M,
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;//
启动计数,HSE状态
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);//HSE使能
  do //循环,直到HSE使能成功或者超时
    StartUpCounter++;
    HSEStatus = (uint32_t)0x01;//HSE
使能成功
  else
    HSEStatus = (uint32_t)0x00;//HSE使能不成功
  if (HSEStatus == (uint32_t)0x01)//HSE使能成功
    FLASH->ACR |= FLASH_ACR_PRFTBE;//flash缓存使能
    /* Flash 2 wait state */
    FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);//
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;//
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;//RCC_CFGR_HPRE_DIV1=0
,CFGR中的值不变
    /* PCLK2 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;//RCC_CFGR_PPRE2_DIV1=0,CFGR中的值不变
    /* PCLK1 = HCLK/2 */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;//低速APB预分频把HCLK 2分频,APB1CLK=HCLK/2
#ifdef STM32F10X_CL
继承事业,薪火相传
