Timing constraint: Default OFFSET IN BEFORE for Clock 'clk'
Total number of paths / destination ports: 74 / 74
这一部分提到的信号及其延迟信息,就是影响最小输入数据建立时间的关键信号或者路径,若要减小该时间,可针对这些信号或路径进行优化。
Offset: 2.327ns (Levels of Logic = 2)
Source: reset (PAD)
Destination: coef_ram_addr_init_0 (FF)
Destination Clock: clk rising
Data Path: reset to coef_ram_addr_init_0
Gate Net
Cell:in->out fanout Delay Delay Logical Name (Net Name)
IBUF:I->O 16 0.754 0.609 reset_IBUF (reset_IBUF)
LUT2:I0->O 14 0.147 0.409 coef_ram_addr_init_and00001 (coef_ram_addr_init_and0000)
FDE:CE 0.409 coef_ram_addr_init_0
Total 2.327ns (1.310ns logic, 1.017ns route)
(56.3% logic, 43.7% route)
Timing constraint: Default OFFSET OUT AFTER for Clock 'clk'
Total number of paths / destination ports: 42 / 42
同理,这一部分提到的信号及其延迟信息是影响模块数据最大输出时间的关键。
Offset: 3.874ns (Levels of Logic = 2)
Source: fir/blk00000003/blk0000089b (FF)
Destination: rfd (PAD)
Source Clock: clk rising
Data Path: fir/blk00000003/blk0000089b to rfd
Gate Net
FDSE:C->Q 9 0.272 0.347 blk0000089b (rfd)
end scope: 'blk00000003'
end scope: 'fir'
OBUF:I->O 3.255 rfd_OBUF (rfd)
Total 3.874ns (3.527ns logic, 0.347ns route)
(91.0% logic, 9.0% route) |
