11. 用下列代码替换Form1.cs文件中的button1组件的Click事件对应的处理代码,下列代码的作用是创建、发送ICMP报文,实现Ping命令:
Private Void Button1_click ( Object Sender , System.eventargs E )
Listbox1.items.clear ( ) ;
String Hostclient = Textbox1.text ;
Int K ;
For ( K = 0 ; K < 3 ; K++ )
Socket Socket = New Socket ( Addressfamily.internetwork , Sockettype.raw , Protocoltype.icmp ) ;
Iphostentry Hostinfo ;
Try
//解析主机ip入口
Hostinfo = Dns.gethostbyname ( Hostclient ) ;
Catch ( Exception )
//解析主机名错误。
Listbox1.items.add ( "没有发现此主机!" ) ;
Return ;
// 取服务器端主机的30号端口
Endpoint Hostpoint = ( Endpoint ) New Ipendpoint ( Hostinfo.addresslist[ 0 ] , 30 ) ;
Iphostentry Clientinfo ;
Clientinfo = Dns.gethostbyname ( Hostclient ) ;
// 取客户机端主机的30端口
Endpoint Clientpoint = ( Endpoint ) New Ipendpoint ( Clientinfo.addresslist[ 0 ] , 30 ) ;
//设置icmp报文
Int Datasize = 4 ; // Icmp数据包大小 ;
Int Packetsize = Datasize + 8 ;//总报文长度
Const Int Icmp_echo = 8 ;
Icmppacket Packet = New Icmppacket ( Icmp_echo , 0 , 0 , 45 , 0 , Datasize ) ;
Byte [ ] Buffer = New Byte [ Packetsize ] ;
Int Index = Packet.countbyte ( Buffer ) ;
//报文出错
If ( Index != Packetsize )
Listbox1.items.add ( "报文出现问题!" ) ;
Return ;
Int Cksum_buffer_length = ( Int ) Math.ceiling ( ( ( Double )index )/ 2 ) ;
Uint16 [ ] Cksum_buffer = New Uint16 [ Cksum_buffer_length ] ;
Int Icmp_header_buffer_index = 0 ;
For ( Int I = 0 ; I < Cksum_buffer_length ; I++ )
//将两个byte转化为一个uint16
Cksum_buffer[ I ] = Bitconverter.touint16 ( Buffer , Icmp_header_buffer_index ) ;
Icmp_header_buffer_index += 2 ;
//将校验和保存至报文里
Packet.checksum = Icmppacket.sumofcheck ( Cksum_buffer ) ;
// 保存校验和后,再次将报文转化为数据包
Byte [ ] Senddata = New Byte [ Packetsize ] ;
Index = Packet.countbyte ( Senddata ) ;
//报文出错
Return ;
Int Nbytes = 0 ;
//系统计时开始
Int Starttime = Environment.tickcount ;
//发送数据包
If ( ( Nbytes = Socket.sendto ( Senddata , Packetsize , Socketflags.none , Hostpoint ) ) == -1 )
Listbox1.items.add ( "无法传送报文!" ) ;
Byte [ ] Receivedata = New Byte[ 256 ] ; //接收数据
Nbytes = 0 ;
Int Timeout = 0 ;
Int Timeconsume = 0 ;
While ( True )
Nbytes = Socket.receivefrom ( Receivedata , 256 , Socketflags.none , Ref Clientpoint ) ;
If ( Nbytes == -1 )
Listbox1.items.add ( "主机没有响应!" ) ;
Break ;
Else If ( Nbytes > 0 )
Timeconsume = System.environment.tickcount - Starttime ;
//得到发送报文到接收报文之间花费的时间
Listbox1.items.add ( "reply From " + Hostinfo.addresslist[ 0 ].tostring ( ) + " In "
+ Timeconsume + "ms :bytes Received " + Nbytes ) ;
Break ;
Timeconsume = Environment.tickcount - Starttime ;
If ( Timeout > 1000 )
Listbox1.items.add ( "time Out" ) ;
Break ;
//关闭套接字
Socket.close ( ) ;
