小弟新手 望各位高手指点错误在那 啊
这段程序老是有警告 warning:fipflop':17'stuck at GND waining:lgnored unnecessary INPUT pin "clk_int" waining:lgnored unnecessary INPUT pin "kk" 程序如下 library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_unsigned.all; use IEEE.std_logic_arith.all; entity DAC is Port (clk_int:in STD_LOGIC; kk:in std_logic; data  ut std_logic_vector(7 downto 0)); end DAC; architecture Behavioral of DAC is signal d:std_logic_vector(7 downto 0); signal count100:std_logic_vector(6 downto 0); begin process(clk_int) begin if(clk_int'event and clk_int='1') then if((count100="1100011")or(kk='1')) then count100<="0110010"; elsif(kk='0') then count100<="0110010"; else count100<=count100+'1'; end if; end if; end process; process(count100) begin case count100 is when "0000000"=>d<="01111111";when "0000001"=>d<="10000111";when "0000010"=>d<="10001111"; when "0000011"=>d<="10010111";when "0000100"=>d<="10011111";when "0000101"=>d<="10100110"; when "0000111"=>d<="10110101";when "0001000"=>d<="10111100";when "0001001"=>d<="11000011"; when "0001010"=>d<="11001010";when "0001011"=>d<="11010000";when "0001100"=>d<="11010110"; when "0001101"=>d<="11011100";when "0001110"=>d<="11100001";when "0001111"=>d<="11100110"; when "0010000"=>d<="11101011";when "0010001"=>d<="11101111";when "0010010"=>d<="11110010"; when "0010011"=>d<="11110110";when "0010100"=>d<="11111000";when "0010101"=>d<="11111010"; when "0010110"=>d<="11111100";when "0010111"=>d<="11111101";when "0011000"=>d<="11111110"; when "0011001"=>d<="11111111";when "0011010"=>d<="11111110";when "0011011"=>d<="11111101"; when "0011100"=>d<="11111100";when "0011101"=>d<="11111010";when "0011110"=>d<="11111000"; when "0011111"=>d<="11110110";when "0100000"=>d<="11110010";when "0100001"=>d<="11101111"; when "0100010"=>d<="11101011";when "0100011"=>d<="11100110";when "0100100"=>d<="11100001"; when "0100101"=>d<="11011100";when "0100110"=>d<="11010110";when "0100111"=>d<="11010000"; when "0101000"=>d<="11001010";when "0101001"=>d<="11000011";when "0101010"=>d<="10111100"; when "0101011"=>d<="10110101";when "0101100"=>d<="10101110";when "0101101"=>d<="10100110"; when "0101110"=>d<="10011111";when "0101111"=>d<="10010111";when "0110000"=>d<="10001111"; when "0110001"=>d<="10000111";when "0110010"=>d<="01111111";when "0110011"=>d<="01110111"; when "0110100"=>d<="01101111";when "0110101"=>d<="01100111";when "0110110"=>d<="01011111"; when "0110111"=>d<="01011000";when "0111000"=>d<="01010000";when "0111001"=>d<="01001001"; when "0111010"=>d<="01000010";when "0111011"=>d<="00111011";when "0111100"=>d<="00110100"; when "0111101"=>d<="00101110";when "0111110"=>d<="00101000";when "0111111"=>d<="00100010"; when "1000000"=>d<="00011101";when "1000001"=>d<="00011000";when "1000010"=>d<="00010011"; when "1000011"=>d<="00001111";when "1000100"=>d<="00001100";when "1000101"=>d<="00001000"; when "1000110"=>d<="00000110";when "1000111"=>d<="00000100";when "1001000"=>d<="00000010"; when "1001001"=>d<="00000001";when "1001010"=>d<="00000000";when "1001011"=>d<="00000000"; when "1001100"=>d<="00000000";when "1001101"=>d<="00000001";when "1001110"=>d<="00000010"; when "1001111"=>d<="00000100";when "1010000"=>d<="00000110";when "1010001"=>d<="00001000"; when "1010010"=>d<="00001100";when "1010011"=>d<="00001111";when "1010100"=>d<="00010011"; when "1010101"=>d<="00011000";when "1010110"=>d<="00011101";when "1010111"=>d<="00100010"; when "1011000"=>d<="00101000";when "1011001"=>d<="00101110";when "1011010"=>d<="00110100"; when "1011011"=>d<="00111011";when "1011100"=>d<="01000010";when "1011101"=>d<="01001001"; when "1011110"=>d<="01010000";when "1011111"=>d<="01011000";when "1100000"=>d<="01011111"; when "1100001"=>d<="01100111";when "1100010"=>d<="01101111";when "1100011"=>d<="01110111"; when others =>null; end case; end process; data<=d; end Behavioral; |
