[求助]niosII设计中关于ADC0809的疑难
在论坛上看到一个姐姐写的程序,有些地方不懂
程序如下:
#include "alt_types.h"
#include <stdio.h>
#include <unistd.h>
#include "system.h"
#include "altera_avalon_pio_regs.h"
/* adc0809 ad_a select*/
void ad_a_select(int ad8switch)  //选择8路模拟信号中的一路
    switch(ad8switch)
      case 0x80: //IN7
           IOWR_ALTERA_AVALON_PIO_DATA(AD_A_PIO_BASE,0x7);
           break;
      case 0x40: //IN6
           IOWR_ALTERA_AVALON_PIO_DATA(AD_A_PIO_BASE,0x6);
           break;
      case 0x20: //IN5
           IOWR_ALTERA_AVALON_PIO_DATA(AD_A_PIO_BASE,0x5);
           break;
      case 0x10: //IN4
           IOWR_ALTERA_AVALON_PIO_DATA(AD_A_PIO_BASE,0x4);
           break;
      case 0x08: //IN3
           IOWR_ALTERA_AVALON_PIO_DATA(AD_A_PIO_BASE,0x3);
           break;
      case 0x04: //IN2
           IOWR_ALTERA_AVALON_PIO_DATA(AD_A_PIO_BASE,0x2);
           break;
      case 0x02: //IN1
           IOWR_ALTERA_AVALON_PIO_DATA(AD_A_PIO_BASE,0x1);
           break;
      case 0x01: //IN0
           IOWR_ALTERA_AVALON_PIO_DATA(AD_A_PIO_BASE,0x0);
           break;
      default:  //warning
           printf("======warning======\n");
           break;
/* start adc0809*/
void ad_start(void)   //adc0809转换程序
  int ad8s;
  //test the value of EOC: the value must be "1"
  printf("eoc_un ?=1: %d\n",IORD_ALTERA_AVALON_PIO_DATA(AD_EOC_PIO_BASE));
  //set ad_start=0
  IOWR_ALTERA_AVALON_PIO_DATA(AD_START_PIO_BASE,0);
  //set ad_ale=0
  IOWR_ALTERA_AVALON_PIO_DATA(AD_ALE_PIO_BASE,0);
  //set ad_oe=0
  IOWR_ALTERA_AVALON_PIO_DATA(AD_OE_PIO_BASE,0);
  printf("eoc_in ?=1: %d\n",IORD_ALTERA_AVALON_PIO_DATA(AD_EOC_PIO_BASE));
  //get the value of AD_8SWITCH_PIO
  ad8s = IORD_ALTERA_AVALON_PIO_DATA(AD_8SWITCH_PIO_BASE);
  //set IN0~IN7
  ad_a_select(ad8s,flag2);
  //set ad_ale=1
  IOWR_ALTERA_AVALON_PIO_DATA(AD_ALE_PIO_BASE,1);  //save the address into the flip-latch of address
  //set ad_ale=0
  //set ad_start=1
  IOWR_ALTERA_AVALON_PIO_DATA(AD_START_PIO_BASE,1); //reset the register
  //set ad_start=0
  IOWR_ALTERA_AVALON_PIO_DATA(AD_START_PIO_BASE,0); //start AtoD
  //test the value of EOC: the value must be "0"
  printf("eoc_t ?=0: %d\n",IORD_ALTERA_AVALON_PIO_DATA(AD_EOC_PIO_BASE));
  while((IORD_ALTERA_AVALON_PIO_DATA(AD_EOC_PIO_BASE))!= 1)
  // whether the conversion of ADC is over:1 is over and the data have been saved into the flip-latch
    printf("test eoc_f ?=1: %d\n",IORD_ALTERA_AVALON_PIO_DATA(AD_EOC_PIO_BASE));
  //set ad_oe=1
  IOWR_ALTERA_AVALON_PIO_DATA(AD_OE_PIO_BASE,1); //put the data to the dataBus
  printf("ad_data is : %d\n",IORD_ALTERA_AVALON_PIO_DATA(AD_DATA_PIO_BASE));
  printf("\n=============AtoD is successful!=================\n");
int main(void)
  while(1)
    ad_start();
程序中
printf("eoc_in ?=1: %d\n",IORD_ALTERA_AVALON_PIO_DATA(AD_EOC_PIO_BASE);请问这句有什么意义?做什么用的啊?试否是做测试?
//set IN0~IN7
这不是定义了一个吗?怎么还有一个啊?
  ad8s = IORD_ALTERA_AVALON_PIO_DATA(AD_8SWITCH_PIO_BASE);中的AD_8SWITCH_PIO_BASE 是什么意思啊? 是怎么来的?接到哪的啊??
希望斑竹和各位高人解释下,还有问这个问题的姐姐能告诉我一下,不胜感激~!!!!
[此贴子已经被作者于2007-5-14 12:58:47编辑过]
printf("eoc_in ?=1: %d\n",IORD_ALTERA_AVALON_PIO_DATA(AD_EOC_PIO_BASE)是确保转换是不是结束。
ad_a_select(ad8s,flag2)是选择通道。
AD_8SWITCH_PIO_BASE 是基地址,你用过pio就知道。
在交流中前进,共同实现nios的应用。
