纸上谈兵: 伸展树 (splay tree)(2)
转自http://www.cnblogs.com/vamei
作者: Vamei 声明 欢迎转载,也请保留这段声明。谢谢!
/* * dealing cases with grandparent node */static void with_grandpa(TREE tr, position np){ position parent, grandPa; int i,j; parent = np->parent; grandPa = parent->parent; i = (grandPa->lchild == parent) ? -1 : 1; j = (parent->lchild == np) ? -1 : 1; if (i == -1 && j == 1) { right_double_rotate(grandPa); } else if (i == 1 && j == -1) { left_double_rotate(grandPa); } else if (i == -1 && j == -1) { right_zig_zig(grandPa); } else { left_zig_zig(grandPa); }}/* * search for value */static position search_value(TREE tr, ElementTP value) { if (tr == NULL) return NULL; if (tr->element == value) { return tr; } else if (value < tr->element) { return search_value(tr->lchild, value); } else { return search_value(tr->rchild, value); }}/* * left single rotation * return the new root */static TREE left_single_rotate(TREE tr) { TREE newRoot, parent; parent = tr->parent; newRoot = tr->rchild; /* detach & attach */ if (newRoot->lchild != NULL) newRoot->lchild->parent = tr; tr->rchild = newRoot->lchild; /* raise new root node */ newRoot->lchild = tr; newRoot->parent = parent; if (parent != NULL) { if (parent->lchild == tr) { parent->lchild = newRoot; } else { parent->rchild = newRoot; } } tr->parent = newRoot; return newRoot;}/* * right single rotation * return the new root */static TREE right_single_rotate(TREE tr) { TREE newRoot, parent; parent = tr->parent; newRoot = tr->lchild; /* detach & attach */ if (newRoot->rchild != NULL) newRoot->rchild->parent = tr; tr->lchild = newRoot->rchild; /* raise new root node */ newRoot->rchild = tr; newRoot->parent = parent; if (parent != NULL) { if (parent->lchild == tr) { parent->lchild = newRoot; } else { parent->rchild = newRoot; } } tr->parent = newRoot; return newRoot;}/* * left double rotation * return */static TREE left_double_rotate(TREE tr) { right_single_rotate(tr->rchild); return left_single_rotate(tr);}/* * right double rotation * return */static TREE right_double_rotate(TREE tr) { left_single_rotate(tr->lchild); return right_single_rotate(tr);}/* * insert a node to a non-empty tree * called by insert_value() */static void insert_node_to_nonempty_tree(TREE tr, position np){ /* insert the node */ if(np->element <= tr->element) { if (tr->lchild == NULL) { /* then tr->lchild is the proper place */ tr->lchild = np; np->parent = tr; return; } else { insert_node_to_nonempty_tree(tr->lchild, np); } } else if(np->element > tr->element) { if (tr->rchild == NULL) { tr->rchild = np; np->parent = tr; return; } else { insert_node_to_nonempty_tree(tr->rchild, np); } }}
* right zig-zig operation
*/static TREE right_zig_zig(TREE tr){ position parent,middle,newRoot; parent = tr->parent; middle = tr->lchild; newRoot = tr->lchild->lchild; tr->lchild = middle->rchild; if (middle->rchild != NULL) middle->rchild->parent = tr; middle->rchild = tr; tr->parent = middle; middle->lchild = newRoot->rchild; if (newRoot->rchild != NULL) newRoot->rchild->parent = middle; newRoot->rchild = middle; middle->parent = newRoot; newRoot->parent = parent; if (parent != NULL) { if (parent->lchild == tr) { parent->lchild = newRoot; } else { parent->rchild = newRoot; } } return newRoot; }
* left zig-zig operation
*/static TREE left_zig_zig(TREE tr){ position parent,middle,newRoot; parent = tr->parent; middle = tr->rchild; newRoot = tr->rchild->rchild; tr->rchild = middle->lchild; if (middle->lchild != NULL) middle->lchild->parent = tr; middle->lchild = tr; tr->parent = middle; middle->rchild = newRoot->lchild; if (newRoot->lchild != NULL) newRoot->lchild->parent = middle; newRoot->lchild = middle; middle->parent = newRoot; newRoot->parent = parent; if (parent != NULL) { if (parent->rchild == tr) { parent->rchild = newRoot; } else { parent->lchild = newRoot; } } return newRoot; } |
