setsebool命令 修改上下文及布尔值
配置VSFTPD时本地用户无法切换
用到命令
setsebool -P allow_ftpd_anon_write=1 allow_ftpd_full_access=1ftp_home_dir=1 ftpd_disable_trans=1 ftpd_is_daemon=1
setsebool命令查询了相关的资料
是selinux的相关设置项
这是SELinux的设置命令.
其实 man 一下setsebool也知道了:
NAME
   setsebool – set SELinuxboolean value
在不熟悉SELnux前,把SELinux关掉也可以的。有时间研究下SELinux。Redhat从FC3开始,就使用了SELinux来增强安全,但是使用起来有时候太繁琐,就想关闭它,但是如果安装服务器的时候开始没有图形界面,还真很难找到地方可以关闭。
正确方法如下:修改/etc/selinux/config文件中的SELINUX=”" 为 disabled ,然后重启。
2009年8。22更新
下面是一些 收集来的 设置命令
===ftp===
//If you want to share files anonymously
chcon -R -t public_content_t /var/ftp
//If you want to setup a directory where you can upload files
chcon -t public_content_rw_t /var/ftp/incoming
You must also turn on the boolean allow_ftpd_anon_write
//If you are setting up this machine as a ftpd server and wish toallow users to access their home directorories
setsebool -P ftp_home_dir 1
//If you want to run ftpd as a daemon
setsebool -P ftpd_is_daemon 1
//You can disable SELinux protection for the ftpd daemon
setsebool -P ftpd_disable_trans 1
===httpd===
//If you want a particular domain to write to thepublic_content_rw_t domain
setsebool -P allow_httpd_anon_write=1
or
setsebool -P allow_httpd_sys__anon_write=1
//httpd can be setup to allow cgi s to be executed
setsebool -P httpd_enable_cgi 1
//If you want to allow access to users home directories
setsebool -P httpd_enable_homedirs 1
chcon -R -t httpd_sys_content_t ~user/public_html
//httpd is allowed access to the controling terminal
setsebool -P httpd_tty_comm 1
//such that one httpd service can not interfere with another
setsebool -P httpd_unified 0
//loadable modules run under the same context as httpd
setsebool -P httpd_builtin_ing 0
//httpd s are allowed to connect out to the network
setsebool -P httpd_can_network_connect 1
// You can disable suexec transition
setsebool -P httpd_suexec_disable_trans 1
//You can disable SELinux protection for the httpd daemon byexecuting
setsebool -P httpd_disable_trans 1
service httpd restart
===named===
//If you want to have named update the master zone files
setsebool -P named_write_master_zones 1
//You can disable SELinux protection for the named daemon byexecuting
setsebool -P named_disable_trans 1
service named restart
===nfs===
//If you want to setup this machine to share nfs partitions readonly
setsebool -P nfs_export_all_ro 1
//If you want to share files read/write
setsebool -P nfs_export_all_rw 1
//If you want to use a remote NFS server for the home directorieson this machine
setsebool -P use_nfs_home_dirs 1
===samba===
//If you want to share files other than home directorie
chcon -t samba_share_t /directory
//If you want to share files with multiple domains
setsebool -P allow_smbd_anon_write=1
//If you are setting up this machine as a Samba server and wish toshare the home directories
setsebool -P samba_enable_home_dirs 1
//If you want to use a remote Samba server for the home directorieson this machine
setsebool -P use_samba_home_dirs 1
//You can disable SELinux protection for the samba daemon byexecuting
setsebool -P smbd_disable_trans 1
service smb restart
===rsync===
//If you want to share files using the rsync daemon
chcon -t public_content_t /directories
setsebool -P allow_rsync_anon_write=1
//You can disable SELinux protection for the rsync daemon byexecuting
setsebool -P rsync_disable_trans 1
===kerberos===
//allow your system to work properly in a Kerberosenvironment
setsebool -P allow_kerberos 1
//If you are running Kerberos daemons kadmind or krb5kdc
setsebool -P krb5kdc_disable_trans 1
service krb5kdc restart
setsebool -P kadmind_disable_trans 1
service kadmind restart
===nis===
Allow your system to work properly in a NIS environment
setsebool -P allow_ypbind 1
1.1 SElinux概述
SELinux(Security-Enhanced Linux) 是美国国家安全局(NAS)对于强制访问控制的实现,在这种访问控制体系的限制下,进程只能访问那些在他的任务中所需要文件。大部分使用 SELinux的人使用的都是SELinux就绪的发行版,例如 Fedora、Red Hat Enterprise Linux(RHEL)、Debian 或 Gentoo。它们都是在内核中启用 SELinux的,并且提供一个可定制的安全策略,还提供很多用户层的库和工具,它们都可以使用 SELinux 的功能。
1.1.1 SElinux特点
1.MAC
对访问的控制彻底化,对所有的文件、目录、端口的访问都是基于策略设定的,可由管理员时行设定。
2.RBAC
对于用户只赋予最小权限。用户被划分成了一些role(角色),即使是root用户,如果不具有sysadm_r角色的话,也不是执行相关的管理。哪里role可以执行哪些domain,也是可以修改的。
3.安全上下文
当启动selinux的时候,所有文件与对象都有安全上下文。进程的安全上下文是域,安全上下文由用户:角色:类型表示。
(1)系统根据pam子系统中的pam_selinux.so模块设定登录者运行程序的安全上下文
(2)rpm包安装会根据rpm包内记录来生成安全上下文,
(3)如果是手工他建的,会根据policy中规定来设置安全上下文,
(4)如果是cp,会重新生成安全上下文。
(5)如果是mv,安全上下文不变。
1.1.2 安全上下文格式
安全上下文由user:role:type三部分组成,下面分别说明其作用:
1.user identity:类似linux系统中的UID,提供身份识别,安全上下文中的一部分。
三种常见的user:
user_u-:   普通用户登录系统后预设;
system_u-:开机过程中系统进程的预设;
root-:   root登录后预设;
在targeted policy中users不是很重要;
在strict policy中比较重要,的有预设的selinux users都以 "_u"结尾,root除外。
2.role
文件与目录的role,通常是object_r;
程序的role,通常是system_r;
用户的role,targeted policy为system_r;
strict policy为sysadm_r,staff_r,user_r
用户的role,类似于系统中的GID,不同的角色具备不同的权限;用户可以具备多个role;但是同一时间内只能使用一role;
role是RBAC的基础;
3.type
type:用来将主体与客体划分为不同的组,组每个主体和系统中的客体定义了一个类型;为进程运行提供最低的权限环境。
当一个类型与执行的进程关联时,该type也称为domain,也叫安全上下文。
域或安全上下文是一个进程允许操作的列表,决字一个进程可以对哪种类型进行操作。
1.1.3 SElinux配置文件
vi /etc/selinux/config
# This file controls the state of SELinux on the system.
# SELINUX= can take one of these three values:
# enforcing - SELinux security policy is enforced.
# permissive - SELinux prints warnings instead of enforcing.
# disabled - SELinux is fully disabled.
SELINUX=enforcing
#SELINUX=disabled
# SELINUXTYPE= type of policy in use. Possible values are:
# targeted - Only targeted network daemons are protected.
# strict - Full SELinux protection.
SELINUXTYPE=targeted
#SELINUX有「disabled」「permissive」,「enforcing」3种选择。
1.模式的设置
enforcing:强制模式,只要selinux不允许,就无法执行
permissive:警告模式,将该事件记录下来,依然允许执行
disabled:关闭selinux;停用,启用需要重启计算机。
2.策略的设置
targeted:保护常见的网络服务,是selinux的默认值;
stric:提供RBAC的policy,具备完整的保护功能,保护网络服务,一般指令及应用程序。
策略改变后,需要重新启动计算机。
也可以通过命令来修改相关的具体的策略值,也就是修改安全上下文,来提高策略的灵活性。
继承事业,薪火相传
