正文
在网络程序设计过程中,我们经常要与各种类型的代理服务器打交道,比如在企业内部网通过代理去访问Internet网上的服务器等等,一般代理服务器支持几种常见的代理协议标准,如Socks4,Socks5,Http代理,其中Socks5需要用户验证,代理相对复杂。我在查阅RFC文档和相关资料后,特总结一些TCP协议穿透代理服务器的程序片断,希望对大家有所帮助。
//使用到的结构
struct sock4req1
char VN;
char CD;
unsigned short Port;
unsigned long IPAddr;
char other[1];
struct sock4ans1
char VN;
char CD;
struct sock5req1
char Ver;
char nMethods;
char Methods[255];
struct sock5ans1
char Ver;
char Method;
struct sock5req2
char Ver;
char Cmd;
char Rsv;
char Atyp;
char other[1];
struct sock5ans2
char Ver;
char Rep;
char Rsv;
char Atyp;
char other[1];
struct authreq
char Ver;
char Ulen;
char Name[255];
char PLen;
char Pass[255];
struct authans
char Ver;
char Status;
//通过Socks4方式代理
if( !ClientSock.Connect( g_ProxyInfo.m_strProxyIP,g_ProxyInfo.m_nProxyPort) )
m_sError = _T( "不能连接到代理服务器! ");
ClientSock.Close();
return FALSE;
char buff[100];
memset(buff,0,100);
struct sock4req1 *m_proxyreq;
m_proxyreq = (struct sock4req1 *)buff;
m_proxyreq-> VN = 4;
m_proxyreq-> CD = 1;
m_proxyreq-> Port = ntohs(GetPort());
m_proxyreq-> IPAddr = inet_addr(GetServerHostName());
ClientSock.Send(buff,9);
struct sock4ans1 *m_proxyans;
m_proxyans = (struct sock4ans1 *)buff;
memset(buff,0,100);
ClientSock.Receive(buff,100);
if(m_proxyans-> VN != 0 || m_proxyans-> CD != 90)
m_sError = _T( "通过代理连接主站不成功! ");
ClientSock.Close();
return FALSE;
//通过Socks5方式代理
ClientSock.Close();
return FALSE;
char buff[600];
struct sock5req1 *m_proxyreq1;
m_proxyreq1 = (struct sock5req1 *)buff;
m_proxyreq1-> Ver = 5;
m_proxyreq1-> nMethods = 2;
m_proxyreq1-> Methods[0] = 0;
m_proxyreq1-> Methods[1] = 2;
ClientSock.Send(buff,4);
struct sock5ans1 *m_proxyans1;
m_proxyans1 = (struct sock5ans1 *)buff;
memset(buff,0,600);
ClientSock.Receive(buff,600);
if(m_proxyans1-> Ver != 5 || (m_proxyans1-> Method!=0 && m_proxyans1-> Method!=2))
ClientSock.Close();
return FALSE;
if(m_proxyans1-> Method == 2)
int nUserLen = strlen(g_ProxyInfo.m_strProxyUser);
int nPassLen = strlen(g_ProxyInfo.m_strProxyPass);
struct authreq *m_authreq;
m_authreq = (struct authreq *)buff;
m_authreq-> Ver = 1;
m_authreq-> Ulen = nUserLen;
strcpy(m_authreq-> Name,g_ProxyInfo.m_strProxyUser);
m_authreq-> PLen = nPassLen;
strcpy(m_authreq-> Pass,g_ProxyInfo.m_strProxyPass);
ClientSock.Send(buff,513);
struct authans *m_authans;
m_authans = (struct authans *)buff;
memset(buff,0,600);
if(m_authans-> Ver != 1 || m_authans-> Status != 0)
m_sError = _T( "代理服务器用户验证不成功! ");
ClientSock.Close();
return FALSE;
struct sock5req2 *m_proxyreq2;
m_proxyreq2 = (struct sock5req2 *)buff;
m_proxyreq2-> Ver = 5;
m_proxyreq2-> Cmd = 1;
m_proxyreq2-> Rsv = 0;
m_proxyreq2-> Atyp = 1;
unsigned long tmpLong = inet_addr(GetServerHostName());
unsigned short port = ntohs(GetPort());
memcpy(m_proxyreq2-> other,&tmpLong,4);
memcpy(m_proxyreq2-> other+4,&port,2);
ClientSock.Send(buff,sizeof(struct sock5req2)+5);
struct sock5ans2 *m_proxyans2;
memset(buff,0,600);
m_proxyans2 = (struct sock5ans2 *)buff;
if(m_proxyans2-> Ver != 5 || m_proxyans2-> Rep != 0)
ClientSock.Close();
return FALSE;
//通过HTTP方式代理
ClientSock.Close();
return FALSE;
char buff[600];
sprintf( buff, "%s%s:%d%s ", "CONNECT ",GetServerHostName(),GetPort(), " HTTP/1.1 User-Agent: MyApp/0.1 ");
ClientSock.Send(buff,strlen(buff)); //发送请求
memset(buff,0,600);
if(strstr(buff, "HTTP/1.0 200 Connection established ") == NULL) //连接不成功
ClientSock.Close();
return FALSE;
我们一般先与代理服务器连通,然后向代理服务器发送代理验证的用户名和密码(如果需要,如Socks5代理),验证成功后,再向代理服务器发送需要连接的目的地址和端口。以上代码仅用于TCP连接,如果在内部网侦听或通过UDP协议发送信息,可查阅RFC1829等文档资料。
用socks5进行udp发送数据的过程:
你的目的是要和服务器做UDP的数据传送。
步骤:
1,和代理建立tcp联接,(你已经完成)。
2,向代理发送版本的请求信息, 我的实现:
void CCommunicator::SendVer()
int datasize = 6;
char tempbuf[6];
tempbuf[0]=5;
tempbuf[1]=4;//标示后面所根的字接数
tempbuf[2]=0;
tempbuf[3]=1;
tempbuf[4]=2;
tempbuf[5]=3;
int senddatalen;
senddatalen=send(m_sock,(char*)tempbuf,6,0);
这一步,你已经返回成功,是吗?如果失败,断开建立的tcp联接,如果成功,如果需要用户验证则进行步骤3,否则进行4. |
