- 1.6.3)printing result
 【2】灵巧求并算法——按集合高度求并2.1)按高度求并定义: 另外一种方法是按照高度求并(按照高度求并是按大小求并的简单修改)(推荐);
2.2)它同样保证所有的树的深入最多是 O(logN)。我们使得 浅的树 成为深 的树的子树,这是一种平缓算法, 因为只有当两颗相等深度的树求并时树的高度才会增加(此时树的高度增加1)。
2.3)source code + printing result
#include <stdio.h>#include <malloc.h>#define ElementType int#define Error(str) printf("\n error: %s \n",str) struct UnionSet;typedef struct UnionSet* UnionSet;// we adopt the depth-sibling exprstruct UnionSet{ int parent; int height; ElementType value;};UnionSet makeEmpty();UnionSet* initUnionSet(int depth, ElementType* data);void printSet(UnionSet* set, int depth);void printArray(ElementType data[], int depth);int find(ElementType index, UnionSet* set);// initialize the union set UnionSet* initUnionSet(int size, ElementType* data){ UnionSet* set; int i; set = (UnionSet*)malloc(size * sizeof(UnionSet)); if(!set) { Error("out of space, from func initUnionSet"); return NULL; } for(i=0; i<size; i++) { set = makeEmpty(); if(!set) return NULL; set->value = data; } return set;}// allocate the memory for the single UnionSet and evaluate the parent and depth -1UnionSet makeEmpty(){ UnionSet temp; temp = (UnionSet)malloc(sizeof(struct UnionSet)); if(!temp) { Error("out of space, from func makeEmpty!"); return NULL; } temp->parent = -1; temp->height = 0; return temp;}// merge set1 and set2 by depthvoid setUnion(UnionSet* set, int index1, int index2){ //judge whether the index1 or index2 equals to -1 ,also -1 represents the root if(index1 != -1) index1 = find(index1, set); if(index2 != -1) index2 = find(index2, set); if(set[index1]->height > set[index2]->height) set[index2]->parent = index1; else if(set[index1]->height < set[index2]->height) set[index1]->parent = index2; else { set[index1]->parent = index2; set[index2]->height++; // only if the height of both of subtrees is equal, the height increases one }} //find the root of one set whose value equals to given valueint find(ElementType index, UnionSet* set) { UnionSet temp; while(1) { temp = set[index]; if(temp->parent == -1) break; index = temp->parent; } return index; } int main(){ int size; UnionSet* unionSet; ElementType data[] = {110, 245, 895, 658, 321, 852, 147, 458, 469, 159, 347, 28}; size = 12; printf("\n\t====== test for union set by depth ======\n"); //printf("\n\t=== the initial array is as follows ===\n"); //printArray(data, depth); printf("\n\t=== the init union set are as follows ===\n"); unionSet = initUnionSet(size, data); // initialize the union set over printSet(unionSet, size); printf("\n\t=== after union(0, 1) + union(2, 3) + union(4, 5) + union(6, 7) + union(8, 9) + union(10 ,11) ===\n"); setUnion(unionSet, 0, 1); setUnion(unionSet, 2, 3); setUnion(unionSet, 4, 5); setUnion(unionSet, 6, 7); setUnion(unionSet, 8, 9); setUnion(unionSet, 10, 11); printSet(unionSet, size); printf("\n\t=== after union(1, 3) + union(5, 7) + union(9, 11) ===\n"); setUnion(unionSet, 1, 3); setUnion(unionSet, 5, 7); setUnion(unionSet, 9, 11); printSet(unionSet, size); printf("\n\t=== after union(3, 7) + union(7, 11) ===\n"); setUnion(unionSet, 3, 7); setUnion(unionSet, 7, 11); printSet(unionSet, size); return 0;}void printArray(ElementType data[], int size){ int i; for(i = 0; i < size; i++) printf("\n\t data[%d] = %d", i, data); printf("\n\n");} void printSet(UnionSet* set, int size){ int i; UnionSet temp; for(i = 0; i < size; i++) { temp = set; printf("\n\t parent[%d] = %d", i, temp->parent); } printf("\n");}
