简单改变FPGA计数器规格使作为DAC功能PWM计数器的纹波降低。 当需要一些模拟输出和系统中有FPGA时,很可能选择使用如图1的PWM模块和简单低通滤波器。FPGA的输出是固定频率、计数器和数字比较器使占空比可变的典型波形(表1)。
假设高信号使能,计数器每个时钟周期进行计数,PWM输出的频率为时钟频率的2次幂分频。通过连接前置比例器,使用使能来降低输出频率。由于输出频率固定,滤波器容易计算。已知占空比50%时,出现最坏的纹波。最大纹波和上升时间的限制结合决定滤波器类型和RC(电阻/电容)值。
对表1中编码进行非小改动,能够改进PWM电路的性能。但在原先系统中,最大纹波电流发生在50%占空比时,最小纹波电流发生在最小占空比时,改进的版本显示最大纹波等于标准版的最小值。关键是产生最高频率的可能性,还能保持平均的占空比常数。输出脉冲频率越高,滤波器性能越好。
从左到右交换所有位来修改由重编二进制比较器组成表1。MSB(最高有效位)变成LSB(最低有效位),LSB变成MSB,等等(表2)。只需重编位,而不需额外寄存器或逻辑单元。
表3显示了4位PWM发出的脉冲序列。表3中,可以看到50%占空比时(第二列,值为8),频率最大,为时钟频率的2分频。在第一个纹波出现点(第二列,值为1),传统PWM系统中有同样的纹波,也就是说,脉冲序列是相同的。
英文原文:
Swapping bits improves performance of FPGA-PWM counter
A simple change to the specification of an FPGA counter lowers the ripple of a PWM counter functioning as a DAC.
Stefaan Vanheesbeke, Ledegem, Belgium; Edited by Charles H Small and Fran Granville -- EDN, 9/13/2007
When you need some analog outputs and you have an FPGA in your system, you probably choose to use a PWM module and a simple lowpass filter such as those in Figure 1. The output of the FPGA is typically a waveform with a fixed-frequency, variable-duty cycle, which a counter and a digital comparator generate (Listing 1).
Suppose that Enable is high, the counter counts up every clock cycle, and the frequency of the PWM output is the clock frequency divided by 2 count bits. You can use Enable to lower the output frequency by connecting it to a prescaler. Because the output frequency is fixed, the filter is easy to calculate, because you know that the worst-case ripple happens at a duty cycle of 50%. The combination of the desired maximum ripple and settling time determines the filter type and RC (resistance/capacitance) values. |
